mentm
So even if i hack it and make it region free I still wont be able to watch Region 1/Zone A blurays?
nope the hack is for dvds only. Bluray hacks are much more difficult.
I know that in this thread it's already been mentioned that USA sold players cannot be hacked. But since I only want to play region 4 DVDs from Brazil (NTSC), is it possible that the hack posted would work on my Sony BDP-S580 if I could find one of the universal remotes with Magic and DVD buttons?
Did you have a US or UK version player?I unlocked my BDP-S580 with URC-3940.
This should work for different SONY blu-ray/DVD players.
I followed carefully all the instructions above and tried all codes:
0533, 00533, 000533. Same for the other 5 codes but nothing seemed to work.
Here I have outlined the basic requirements to complete this task successfully.
It's for those like me who've found this old post and have spent a good day figuring out
how to work around it with a different One-For-All URC model.
1. You need a universal remote control "One For All" brand with the "DVD" and "Magic" buttons.
I found some: URC-3440, URC-3940, URC-7040, URC-7140, URC-7562, URC-7710, URC-7950
but any OFA RC model with those two buttons should work just fine.
2. If your remote is not one of those mentioned in the post you need to have the manual for that
particular model, or find it in the manufacturer's website. It can be downloaded as a PDF.
Your remote may use 4, 5, or 6 digit codes (see your manual).
Go under DVD codes/Sony and find the one that looks closest to 0533.
Mine was 20533.
3.Programming of the One-For-All remote is done with your SONY device plugged in the power outlet and turned off (Standby mode).
4. Other (SONY) devices connected to the player may interfere with the hack so leave just the TV connected or you can disconnect it as well.
All indications needed for the task are found on the player's display.
5. Over a period of time (if connected to the internet) the player will ask for a firmware update.
I'm not sure if the unlock remains after the update or it wipes off but I'll let you know soon.
For now don't go selling or giving away your remote once you're done!
(Again this is for the BDP-S580 with URC-3940)
1. Press DVD
2. Hold the magic button until the power (or DVD) button flashes twice.
3. Press 20533 (first Sony DVD code in the URC-3940 manual)
4. Hold the magic button until the power (or DVD) button flashes twice.
5. Press 994
6. Press Magic Key (don't hold)
7. Press 00189 (add or subtract a zero for 6 or 4 digit coded remote)
8. Press 1 (this sets key 1 – the button flashes twice)
9. Hold the magic button until the power (or DVD) button flashes twice.
10. Press 994
11. Press Magic Key (don't hold)
12. Press 00255 (add or subtract a zero for 6 or 4 digit coded remote)
13. Press 2 (this sets key 2 – the button flashes twice)
14. Hold the magic button until the power (or DVD) button flashes twice.
15. Press 994
16. Press Magic Key (don't hold)
17. Press 00095 (add or subtract a zero for 6 or 4 digit coded remote)
18. Press 3 (this sets key 3 – the button flashes twice)
19. Hold the magic button until the power (or DVD) button flashes twice.
20. Press 994
21. Press Magic Key (don't hold)
22. Press 00221 (add or subtract a zero for 6 or 4 digit coded remote)
23. Press 4 (this sets key 4 – the button flashes twice)
24. Hold the magic button until the power (or DVD) button flashes twice.
25. Press 994
26. Press Magic Key (don't hold)
27. Press 00079 (add or subtract a zero for 6 or 4 digit coded remote)
28. Press 5 (this sets key 5 – the button flashes twice)
Done - the remote is now programmed and ready to use
1. Now to make your player region free use the SONY remote that came with the player to bring it out of standby (turn on) and wait while HOME is displayed
2. Make sure there isn't a disc in the machine.
3. Now on the One-For-All remote press 1, 2, 3, 4, 5 (You'll see OK displayed and the blue 24p light on the player will start flashing)
4. Put the player back into standby (turn off) with the SONY remote
5. The next time you turn on the player it will be region free for DVD playback
If the blue 24p light doesn't flash then it hasn't worked, try a new set of batteries and start a fresh.
