Sony BDP-S580 multi region DVD hack with URC-3440
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by lr101fc, Jun 11, 2011.
  1. lr101fc
    lr101fc Member
    Jan 4, 2008
    10
    Thanks to Whirlybat for his earlier post :)
    I have a Sony BDP-S580. I had bought it under the understanding that it was already DVD multiregion or region free. :oops:
    After unpacking and setting up, I tried a region 2 disc, all worked OK. Followed by a region 1 disc - error message that disc could not be accessed due to region coding - not a happy bunny ! :mad:
    So I then followed whirlybat's earlier post (the same one I used for my Sony BDP-S470) with an One for All remote URC-3440 to make it multi region. I used the following instructions with the additional leading 0's that whirlybat used for his 7562 remote and the hack worked first time :clap:
    Quote whirlybat "Ok I worked it out. For the 7562 remote you need to add 00 to the key setting numbers given in the first post"
    "They don't appear to have the 7040 model at Argos so this might help somebody" :smashin: - It helped me :)
    Programming the 7562 OneforAll remote to enable region free playback of DVD’s on the Sony BDP-S350
    Also programming the URC-3440 remote for the Sony BDP-S580 to enable region free playback of DVDs only.
    1. Press DVD
    2. Hold the magic button until the DVD button flashes twice.
    3. Press 000533
    4. Hold the magic button until the DVD button flashes twice.
    5. Press 994
    6. Press Magic Key (don't hold)
    7. Press 001891 (this sets key 1 – the DVD button flashes twice)
    8. Hold the magic button until the DVD button flashes twice.
    9. Press 994
    10. Press Magic Key (don't hold)
    11. Press 002552 (this sets key 2 – the DVD button flashes twice)
    12. Hold the magic button until the DVD button flashes twice.
    13. Press 994
    14. Press Magic Key (don't hold)
    15. Press 000953 (this sets key 3 – the DVD button flashes twice)
    16. Hold the magic button until the DVD button flashes twice.
    17. Press 994
    18. Press Magic Key (don't hold)
    19. Press 002214 (this sets key 4 – the DVD button flashes twice)
    20. Hold the magic button until the DVD button flashes twice. .
    21. Press 994
    22. Press Magic Key (don't hold)
    23. Press 000795 (this sets key 5 – the DVD button flashes twice)
    Done - the remote is now programmed and ready to use
    1. Now to make your player region free use the Sony remote that came with the player to bring it out of standby and wait while HOME is displayed
    2. Make sure there isn't a disc in the machine.
    3. Now on the OneforAll remote press 1, 2, 3, 4, 5 (The blue 24p light on the player will start flashing)
    4. Put the player back into standby with the Sony remote
    5. That’s it, the next time you turn on the player it will be region free for DVD playback
    If the blue 24p light doesn’t flash then it hasn’t worked, try a new set of batteries and start a fresh
  2. Crookloq
    Crookloq Member
    Sep 30, 2007
    26
    3
    I can't find these remotes for sale anywhere, are there any hacks for the Sony BDP-S580 on anything else?:lease:
  3. smm2303
    smm2303 Member
    Sep 29, 2008
    16
    Please any one can help me how to use Logitech Harmony 525 as one4all URC-3440:lease:
    I want to hack Sony BDP-S580 (USA Model)
    Thank you
  4. mentm
    mentm Active Member
    Jun 20, 2008
    3,716
    +416
    usa players can't be hacked i am afraid.
  5. ninjacat
    ninjacat Member
    Aug 12, 2011
    2
    Hello,
    I own a BDPS580 I tried to make it multi region using a 7562 remote and although programming the remote works properly, the dvd player itself doesn't register when I press, 1,2,3,4 and 5 at the end. After pressing these and putting my region 1 it comes up with the playback prohibited because of region code error. Am I using the right remote? or do I need different codes for the player? I followed all instructions in this post accurately and even changed the batteries for the remote although it flashes when it is supposed to etc,.?
    Any advice greatly appreciated,
    Kind Regards
    Becca
  6. mentm
    mentm Active Member
    Jun 20, 2008
    3,716
    +416
    The correct method is take player out of standby, press 1, 2, 3, 4, 5 then put into standby again. Then the blue light should flash. Finally disconnect from the mains to stop the flashing blue light. Worked first time for me.
  7. ninjacat
    ninjacat Member
    Aug 12, 2011
    2
    Hello everyone,
    Just wanted to give an update. Well, the hack works for me now, I used a one for all URC-7562 remote on the sony BDPS580 (uk model), I followed the instructions as outlined here but as you know from my previous post it wasn't working.
    I discovered why......It wasn't working because I had my sony ps3 and sony ps2 connected. I disconnected them from the mains leaving only the dvd player connected and tried the hack again and it worked perfectly on first try!!! :)
    It may seems obvious to some people that you may need to disconnect your other sony things but I kept them connected before and it appears they were all conflicting with the hack. Hope this post helps other people who maybe canny figure out why this wasn't working for them before.
    Becca
  8. andysm
    andysm Member
    Aug 15, 2008
    29
    3
    Hi, thanks for this. I just used this hack with a One-for-all URC-7950 on a BDP-S480, it worked with just one tweak, in step 3 I just entered 0533 (without the other 2 leading zeros). All other steps were exactly as above (the DVD button doesn't flash on the 7950, the power button does instead).
  9. asaburub
    asaburub Member
    Sep 23, 2011
    I had brought the s580 from the states to the Jordan where im staying now, it worked fine at first, now it cannoct access youtube and other video services due to region control... any tips?!?
  10. valtjyrk
    valtjyrk Member
    Nov 2, 2011
    I used URC-7140 and the hack worked with it. First code is four-digit (0533 which is Sony dvd-players code) and all the others are exactly the same as above. (994, 001891, 994, 002552, ...).
    I suppose that the hack will work with any OFA-remote which has DVD-ability and magic button.
  11. shaunstrudwick
    shaunstrudwick Member
    Jan 6, 2009
    167
    +7
    hi - i'm a noob when it comes to these universal remotes...
    what can i control with them?
    I have Sky HD, Sony KDL-W5710 and looking to get one of these Sony BDPS580 blu ray players
    at the moment just use my Sky remote to control both Sky and tv
  12. mentm
    mentm Active Member
    Jun 20, 2008
    3,716
    +416
    It will control those three items, you can check the one for all website for any other devices.
  13. ROZ
    ROZ Member
    Jan 4, 2005
    120
    I've just plugged in my new S580, which I bought on the basis of it being multiregion as the suppliers website stated, and as I reconfirmed over the phone when I bought it. And guess what, it doesn't play my region 1 DVDs! So someone will be getting a call in the morning to explain what's happened.
    There's not a setting or anything is there? I know there wasn't with the multiregion DVD player I've just taken out...
  14. mentm
    mentm Active Member
    Jun 20, 2008
    3,716
    +416
    No setting once it has been hacked it's fully automatic. Sounds as though they 'forgot' to hack yours.
  15. eastx
    eastx Member
    Dec 8, 2011
    4
    Are we completely sure the code doesn't work for the US version of this player?
  16. mentm
    mentm Active Member
    Jun 20, 2008
    3,716
    +416
    Yes, usa player can't even play PAL discs
  17. ROZ
    ROZ Member
    Jan 4, 2005
    120
    Apparently so. PRC Direct have admitted this oversight and it's back on its way to Ilford right now. They say they "mod" it and send it straight back, all at their cost.
    Mail order, fantastic until it goes wrong..
  18. solo3413
    solo3413 Member
    Dec 20, 2011
    4
    OK guys but what about BLurays?
    This works for DVDs but how to proceed for BD ? :lease:
  19. mentm
    mentm Active Member
    Jun 20, 2008
    3,716
    +416
    You'll need a hardware mod for blurays which will be expensive.
    • Thanks Thanks x 1
  20. eddywatson
    eddywatson Member
    Feb 9, 2009
    74
  21. solo3413
    solo3413 Member
    Dec 20, 2011
    4
    yep but you will still not be able to read A-Zone and C-Zone Blu-rays. TO do so, you'll have to spent another couple hundreds ....
    :-( as I did ....
  22. solo3413
    solo3413 Member
    Dec 20, 2011
    4
    thanks mentm anyway
  23. eddywatson
    eddywatson Member
    Feb 9, 2009
    74
    what are A-zone and C-zone?
  24. solo3413
    solo3413 Member
    Dec 20, 2011
    4
    Almighty gods of bluray decided once that humans could not exchange each others bluray discs across continents.
    As DVDs gods had used this trick once (zone 1, zone 2 etc...) but had been cheated by the wild tribe of forumists" all in one". Gods of blurays made it so hard to free their players that spending 200 gold coins to update/multiply one's hardware was required to reach culture free market. A is America, B is Europe & Africa, C is Asia. Many blu-ray discs are region free but some EXCELLENT titles edited by e.g. Criterion demand an A-player.
    Owner of a B (regular player), I had to buy this A player despite my all in one remote. Not ecological, not smart, useless from a market standpoint....accelerating the fall of physical medias... Well this is god's stuff...
  25. eddywatson
    eddywatson Member
    Feb 9, 2009
    74
    So even if i hack it and make it region free I still wont be able to watch Region 1/Zone A blurays?
  26. mentm
    mentm Active Member
    Jun 20, 2008
    3,716
    +416
    nope the hack is for dvds only. Bluray hacks are much more difficult.
  27. Scottie99
    Scottie99 Member
    Dec 29, 2011
    I just received the BDP-S580 for christmas (I'm in the US), is it possible to make the player DVD region free without needing a universal remote?
    Or do I need to go out and buy a universal remote too in order to make it region free?
    Thanks in advance for your help.
  28. mentm
    mentm Active Member
    Jun 20, 2008
    3,716
    +416
    Yes you need a certain remote
    But it does not work on USA players
  29. pariscope
    pariscope Member
    Feb 7, 2012
    2
    Hi, i have just bought a one-for-all remote URC-3440 to hack my Sony BDPs480. Could you be so kind to assist me how to hack the blu-ray player so i may activate for dvd code free. Thanking you in advance, Pariscope
  30. stevestarr13
    stevestarr13 Member
    Jan 15, 2004
    I have one of these players coming in the mail. Can I use any one4all repote or are there specific ones needed?
    thanks
    Steve
