Sony BDP-S490 - region free
Discussion in 'Blu-ray & DVD Players' started by crush123, Jan 9, 2013.
  1. crush123
    crush123 Member
    Jan 11, 2007
    41
    I have seen a couple of related posts to make this model region free using an all in one remote.
    I wondered if anyone has had any success with software 'magic' remotes.
    we have android and ipod devices and didn't want to spend a tenner on something i would use once, if there was an app out there.
  2. mentm
    mentm Active Member
    Jun 20, 2008
    3,672
    +410
    Do those devices use infra-red i thought they were all wifi based?
  3. tompop
    tompop Member
    May 12, 2011
    679
    +50
    I don't think they would work they have to be a certain type of remote not just any remote will work...I'd ask around to see if anyone you know have one...I did read on one forum someone brought a remote from Maplin one of those discount unboxed ones did the code then returned it saying it didn't work haha.
  4. crush123
    crush123 Member
    Jan 11, 2007
    41
    Thanks for your replies.
    I found an all-in-one urc-7740 on ebay for 6 quid.
    Will update this thread when I have tried it
    Update.
    used this thread
    Little bit of trial and error, but it works.
    I found with the 7740, the 5 digit code in step 3 didn't work for me, but 0533 did.
    Followed the rest of the instructions exactly.
    On pressing 1,2,3,4,5, the led display on the S490 showed 'OK'.
    Restarted and it works.
