Softmodded xbox wont run original game
Discussion in 'Original Xbox' started by semiskimmed, May 26, 2011.
  1. semiskimmed
    semiskimmed Active Member
    Jun 30, 2005
    4,523
    +213
    after recently installing a larger hard drive in my xbox and doing the softmod, when ive put in my original! PGR2, it just crashes as soon as you press a button on the opening sequence.
    anyone got any ideas?
    i did think it was a savegame problem but ive deleted it using the original xbox dashboard but any help would be great :thumbsup:
    (please remember this is an original game and im not asking for help to run copied games!)
  2. Switch625
    Switch625 Member
    Jan 15, 2005
    1,234
    +111
    Try clearing the cache, I think it might be on E:
    • Thanks Thanks x 1
  3. Chett
    Chett Member
    Apr 13, 2009
    278
    28
    +88
    As Switch mentions, try deleting the contents of folder E/Cache & also the contents of folders X,Y & Z
    • Thanks Thanks x 1
  4. semiskimmed
    Jun 30, 2005
    4,523
    +213
    thanks for this, i will try it now.
    /edit, cheers guys, deleting the cache worked :)
