Small file, how large could I blow it up?
Discussion in 'Photo Sharing' started by ziplex, Feb 26, 2012.
  1. ziplex
    ziplex Member
    Apr 20, 2006
    398
    +25
    I finally got around to using my Lencarta flash head for the first time......took a few of the brat and liked this one. It wasn't until downloading that I realised I had previously turned the quality down to take some pic's to e mail to someone. File size is less than 700kb :(
    Any ideas on what size I could enlarge it to? Rarely do I bother with prints but we've decided to start getting some done, oh....I could kick myself!
  2. ziplex
    ziplex Member
    Apr 20, 2006
    398
    +25
    Have I put this in the wrong section :confused: loads of views and no one with an answer? where's all the tech' heads when you need one :laugh:
  3. shotokan101
    shotokan101 Well-Known Member
    Jun 16, 2009
    54,651
    +12,319
    Need a bit more info. TBH - the supplied image is less that 1000x1000 resolution so I'm assuming that the original jpeg (why not shooting RAW BTW?) is a lot higher resolution and that will have a substantial impact on how large you can print :)
    Also how are you planing to view it - what viewing distance etc. ?
    Lovely shot BTW
    Jim
  4. ziplex
    ziplex Member
    Apr 20, 2006
    398
    +25
    Jim,
    It's 980x775....I think, as mentioned in original post I had changed camera settings to post some pic's via e mail of a jacket of all things then merrily shot away with the flash/daughter only to realise I hadn't changed it back to RAW etc. So, it's a tiny file of a shot we really like of our daughter, me and the mrs wanted to get an enlarged print done but the file size, I assume, will make it prohibitive.........rarely do we get prints done and when we have previously they have been from a large file. I guess had we of been able it would of been nice to do a 16x20, obviously out of the question now?!
  5. shotokan101
    Jun 16, 2009
    54,651
    +12,319
    That's a pity - when you said originally that you had turned the quality down I thought you meant the jpeg quality down from fine to medium or similar and still had a higher res jpeg to work from than the attachment size posted :(
    Jim
  6. simonblue
    simonblue Active Member
    Jan 29, 2006
    10,744
    +1,635
    You might be able to get an A4 size from it :)
  7. ziplex
    ziplex Member
    Apr 20, 2006
    398
    +25
    Sadly not................
  8. ziplex
    ziplex Member
    Apr 20, 2006
    398
    +25
    Well, that's a starting point........we'll give it a go and see what we get back :smashin:
  9. mucca_D
    mucca_D Member
    Jan 31, 2005
    1,871
    116
    +515
    How big do you want it? Am sure I can do somthing with it.
  10. ziplex
    ziplex Member
    Apr 20, 2006
    398
    +25
    As large as is realistic............was surprised A4 might work to be honest, any larger would be a bonus.
  11. liamt
    liamt Active Member
    Aug 18, 2009
    9,359
    +1,795
    Bit leftfield this one but: why not have a play in photoshop with it? Try something like an oil brush effect - they can look awesome printed. You might be able to get away with resizing large then the filter as the sharpness isn't as important. Also in photoshop there are a few guff weeny methods of resizing. They often look the same but can sometimes make a difference
    You could also do something like a live trace on illustrator which creates a vector that will upscale perfectly but that is another effect setting rather than pure photo. You could then import to photoshop and mess with filters like the various crayon ones that can look cool if you are lucky
    Unfortunately there is no magic super enhance software like in the movies so standard printing after resize will never look as good as if you used the raw setting :( its a bummer when stuff like this happens. Always shoot in highest settings and resize after. Much easier to shrink than blow up
  12. ziplex
    ziplex Member
    Apr 20, 2006
    398
    +25
    Aye.......it was a dumb mistake :facepalm: I have had a play with this and a few other images in LR with some good results so will tinker a bit more :smashin:
  13. mucca_D
    mucca_D Member
    Jan 31, 2005
    1,871
    116
    +515
    I see you have cropped it a little already? to a 10x8 1.25 ratio.
    I have enlarged in CS5 through onOne Perfect Resize
    I increased to 150DPI gives a 2937x2334
    http://www.welshtog.co.uk/avf/breezeEdit.jpg 2.8mb
    This should be fine for 10x8 upto A4 ish
    http://www.welshtog.co.uk/avf/breezeEdit1.jpg 8.9mb
    This one I pushed to 6000x4800 300DPI sized for a 20"x8" print
    Upto you if you go ahead and print of course
    Doug
  14. shotokan101
    Jun 16, 2009
    54,651
    +12,319
    Very impressive results :)
    • Thanks Thanks x 1
  15. ziplex
    ziplex Member
    Apr 20, 2006
    398
    +25
    Doug,
    I really do appreciate this...........:blush: you're a saint and rest assured I will certainly get some prints done.......thank you very much! (will let you know the outcome too)
  16. Ibcus
    Ibcus Member
    Apr 19, 2008
    1,223
    83
    +271
  17. shotokan101
    Jun 16, 2009
    54,651
    +12,319
  18. Ibcus
    Ibcus Member
    Apr 19, 2008
    1,223
    83
    +271
    I used Photoshpo CS5.
    I made a new action to resize by 10% each time.
    Actions, new action(bottom right), name it Upscale 10%
    Click record.
    Click Image, Image Size.
    Under Document size click the drop down and change to percent (Height and Width should both be percent).
    Change the values to 110%.
    I changed Resolution to 180 pixels/inch (300 for the last one)
    Drop down at the bottom change to Bicubic Smoother(best for enlargement)
    Click ok
    Click stop in the action pain.
    This should resize the picture by 10%, you can keep playing the action to resize by 10% untill you get what you are after.
    To finish I sharpened the edges with an action I have.
    • Thanks Thanks x 2
  19. shotokan101
    Jun 16, 2009
    54,651
    +12,319
    :cool: :thumbsup: :smashin:
  20. RajP
    RajP Active Member
    Feb 5, 2005
    5,550
    +1,793
    You guys are just awesome... To have taken a small image to these sizes is brill... Very very impressive.. Wish I could get my head around using CS5...
  21. ziplex
    ziplex Member
    Apr 20, 2006
    398
    +25
    I wish I could get my head around it, full stop :laugh:.......great stuff :smashin:
  22. pixelpixel
    pixelpixel Active Member
    Jul 2, 2005
    12,390
    +1,777
    • Thanks Thanks x 1
  23. liamt
    liamt Active Member
    Aug 18, 2009
    9,359
    +1,795
    photoshop isnt too bad. you should see what it was like in version 3 when i first started using it. i have to admit i love photoshop, by far my favourite bit of software, but user friendly it is not. well, if you are new to it.
  24. ziplex
    ziplex Member
    Apr 20, 2006
    398
    +25
    Collected via my sister just a minute ago, an 18 x 12 (nearest to rec') and a 10 x 8 print...they really are rather nice, in fact they look wonderful :)
    Thanks again Doug...much appreciated, daughter is chuffed too :smashin:
