SkyHD Box Very Slow to Turn On
Discussion in 'Sky, Sky+, Sky HD & Sky 3D' started by bigfecker, May 23, 2010.
  1. bigfecker
    bigfecker Member
    Jul 23, 2003
    440
    +17
    My SkyHD box has developed a curious fault.
    On Thursday morning it would not come out of standby so I switched it off at the mains and on and it was fine. The same has continued to happen since then.
    After the box has been off (red light on) about an hour it fails to switch back on. There are two ways to get it to come on either mains on and off or if I hold the power button down for several minutes I hear the HD spin up and it comes on. Both of these 'resets' result in the box scanning for channels and it starting up on the Sky Demo channel.
    This is an original Thomson :suicide: :thumbsdow box. I've done a full reset and formatted the HD etc but the same issue persists.
    Any Ideas? My next step is to change the HD.
    (Just realised wrong forum, could someone move to the Sky HD for me)
  2. anfukf
    anfukf Member
    Nov 19, 2008
    463
    28
    +61
    If it has not been done the psu is the likely suspect.
  3. bigfecker
    bigfecker Member
    Jul 23, 2003
    440
    +17
    Change the HD earlier still not solved the problem. Looks like a faulty PSU.
