Sky + remote does not work
Discussion in 'Sky Forum' started by lee771, Jul 31, 2011.
  1. lee771
    lee771 Member
    Jun 16, 2011
    17
    I have connected a sky eye to my sky + box, the rf outlet is on and the light on the eye is on, but my sky remote will not work it, any ideas?
    I have a skyHD as well which the remote works fine on, very frustating!
  2. logiciel
    logiciel Moderator
    Feb 2, 2008
    46,296
    +4,488
    These "eyes" are normally used for sending the remote control back to the Sky receiver from a remote location, where they're connected between the cable from the receiver's RF2 Out socket and the remote TV.
    If you're using it in the same room, try it on a length of co-ax cable, away from the receiver and the TV.
  3. lee771
    lee771 Member
    Jun 16, 2011
    17
    My sky box is in the garage and the eye is in another room, cant understand why it will not work. I have 4no other eyes around the house which are working off the sky HD box which are fine.
  4. logiciel
    logiciel Moderator
    Feb 2, 2008
    46,296
    +4,488
    You said you "have connected a sky eye to my sky + box" - you actually meant you'd connected it to the extension TV in the usual way?
    In that case it's probably a slight fault in the cable that can easily let the programme through one way but prevent the IR getting back the other.
  5. MartinPickering
    MartinPickering Active Member
    Sep 23, 2009
    4,615
    +470
