Sky remote codes for SAMSUNG TV
Discussion in 'Sky Forum' started by Chach007, Jun 5, 2007.
  1. Chach007
    Chach007 Member
    Apr 29, 2007
    45
    Hi guys,
    My mate has recently bought a SAMSUNG LE40R88BDX lcd tv and cannot find a 3 digit code that enables him to use his Sky remote to control his tv. He's tried at least 6 from various websites promoting them as for Samsung models. Any one got one of these tv's and knows a code that would work or could point me in the right direction I'd be very thankfull.
    Cheers,
    Chach :thumbsup:
  2. John Henry
    John Henry Member
    Aug 8, 2006
    935
    +39
    Just checked in the sky manual and the set up code for Samsung tv's is 0060.
  3. JayCee
    JayCee Active Member
    Jan 20, 2004
    15,594
    +1,564
    Try 0088
    It may not work if it's an old revision of the Sky remote.
  4. CatDog
    CatDog Member
    Apr 20, 2001
    94
    I've got the same TV and I'm pretty sure 0060 works. It's definitely a four digit code (I tried all the 'threes' first without success !).
  5. Heinz
    Heinz Member
    Aug 4, 2005
    408
    +19
    Courtesy of http://www.satcure.co.uk/tech/digicode2.htm
    SAMSUNG
    LE19R71B
    SKY Rev 4 or earlier
    646
    LE23T51B
    SKY+ Rev 6
    SKY Rev 6
    0646
    088
    LE23T5(B)
    SKY Rev 6
    646
    LE26R41B
    SKY Rev 8
    672
    LE26R41BD S
    SKY Rev 6 + 8
    0646
    LE26R41BDX/XEU
    SKY+ Rev 4 or earlier
    646
    LE26R51BD
    SKY+ Rev 6
    646
    LE26R51BD
    SKY Rev 6
    088
    LE26R74BD
    088, 646
    LE32M51BX
    SKY+ Rev 4
    646
    LE32N73
    088
    LE32R41B LCD
    SKY+ Rev 6
    0646
    LE32R41BD\\X
    SKY Rev 6
    646
    LE32R51BD
    SKY Rev 3
    0088
    LE32R51PD
    SKY Rev 6
    0646
    LE32R72BX
    646
    LE32R73BD
    SKY Rev 4
    646
    LE32R73BD
    Sky Rev 8
    0672
    LE32R74BDX/XEU
    SKY Rev 6
    646
    LE37R74BD
    SKY Rev 6
    0060, 646
    LE37R74BDX
    0646
    LE37S7
    0646
    LE40 F71BX
    SKY+ Rev 6
    0060
    LE40M8
    0088
    LE40N73BD
    088
    LE40N73BD
    SKY+ Rev 6
    0646
    LE40R5
    SKY Rev 5,
    SKY Rev 6
    646
    LE40R41B
    SKY Rev 8
    672
    LE40R51B
    SKY+ Rev 1
    088
    LE40R51BX/XEU
    SKY+ Rev 4
    646
    LE40R7
    SKY Rev 6
    0060
    LE40R73BD
    SKY Rev 6
    0060
    LE40R73BD
    SKY+ Rev 6
    0646
    LE40R74BD
    SKY+ Rev 6/8
    0646
    LE40R74BDX
    0672
    LE40R74BDX
    0646
    LE40R74BDX/XEU
    088
    LE46M87BD
    0646
    • Thanks Thanks x 2
  6. Chach007
    Chach007 Member
    Apr 29, 2007
    45
    Thanks all for replying. Yes the 4 digit code of 0088 worked a treat for him. :thumbsup:
  7. skull-eater
    skull-eater Member
    Aug 28, 2005
    209
    +5
    :)hi ive just got asamsung le37r87bd can any one please help with sky code tryed 0060/0088.the remote number is URC-1610-00 B00 thanks guys:
  8. JayCee
    Jan 20, 2004
    15,594
    +1,564
    If there is no "rev no" on a label in the Sky remote battery compartment it's likely this is an old version remote and it will not have the codes for your TV.
  9. jingo_man
    jingo_man Member
    Jul 6, 2007
    9
    i have tried many 3 and 4 digit codes to get my samsung LE37R87BDX tv to work with the sky+ remote.
    the only ones that work are:
    646
    0646
    0066
    0088
    however, not all buttons map correctly. if i use the "tv guide" button, or any of the other 3 buttons on this row, the sky+ recieves the command properly, but the tv changes to use the standard channels, rather than the "EXT1" scart connection. i then have to put in back onto this channel with the samsung remote. very annoying as volume and other keys work fine.
    are there other codes that will resolve this problem?
    regards,
    dan burt
  10. Jimmo 32
    Jimmo 32 Member
    Apr 22, 2007
    211
    +24
    Take the battery cover off to see what version your remote is,eg rev4(oldest) rev6, rev8(latest)) Older remotes wont work with the new lcds.Or try a similar model number,using the sky interactive button,and follow the on screen instructions:smashin:
  11. skull-eater
    skull-eater Member
    Aug 28, 2005
    209
    +5
    ive same telly 0646 worked for me
  12. bellamy_47
    bellamy_47 Member
    Nov 15, 2006
    183
    +20
    0646 works on the new ps50c96hdx and ps50q97hdx plasmas, I'd say the 42" ones as well.
  13. adambham
    adambham Member
    Jun 19, 2008
    2
    Hi, Ive jst purchased a Samsung LE40A559P and am unable to programme the Sky remote to work on the telly. I have looked on the net, called Sky and Samsung but to no avail. Can anyone help? :lease:
  14. JayCee
    Jan 20, 2004
    15,594
    +1,564
    By "am unable to programme the Sky remote to work on the telly"...do you mean you don't know how to do it or are you asking for the code for your TV?
    If the latter what revision of the Sky remote do you have?...it's on a label in the battery compartment.
    Is it a standard Sky box or Sky+?
  15. fernandez
    fernandez Active Member
    Jun 5, 2005
    6,028
    +1,039
    This may help
    http://www.sjstv.co.uk/skycodes.html
    Welcome to the forum but it may have been better starting a new thread (and easier to find your answer) than 'gravedigging' this old one:)
  16. robin635
    robin635 Member
    Jun 29, 2006
    72
    +6
    Just saved my bacon thanks
