Sky remote code for Sony TV's
Discussion in 'Remote Controls' started by Ixon, Mar 9, 2003.
  1. Ixon
    Ixon Member
    Jul 3, 2002
    181
    +4
    Hi has anybody got the Sky remote codes for sony TV's and if so what do you do to make your Sky remote work with your TV.
  2. mmm
    mmm Member
    Dec 6, 2002
    98
    Make sure your TV is on.
    press "TV" on your sky remote
    hold down both "SELECT" and then "RED" button until the little LED blinks twice on your sky remote. (should be for about 2 seconds)
    press "TV" again
    enter the code "0000" on your sky remote
    the little LED should blink twice again. (if it didnt, restart the process)
    if it had blink twice, then press the "STANDBY" button on the sky remote - your TV should turn off. (if it didnt, restart process again)
    if it did - press "SELECT" the little LED should blink twice again, and hey presto - you is programmed ;)
    hope this helps...
    • Thanks Thanks x 1
  3. Ixon
    Ixon Member
    Jul 3, 2002
    181
    +4
    Thanks it did :p
  4. lynx
    lynx Active Member
    Jan 20, 2002
    4,636
    +319
    Had you used the search function you would have found this and if you look a little deeper this link.
  5. lynx
    lynx Active Member
    Jan 20, 2002
    4,636
    +319
    Moving to the correct forum.
  6. play365
    play365 Member
    Mar 5, 2008
    2
    Worked for me thank you :D
  7. Martin26
    Martin26 Member
    Dec 27, 2010
    3
    This has worked for my Sony Bravia KDL-40EX503 tele bought Dec 2010 using code 0000
    • Thanks Thanks x 1
