sky remote code for LG
Discussion in 'Sky, Sky+, Sky HD & Sky 3D' started by psoutham123, Sep 4, 2008.
  1. jono t
    jono t Member
    Mar 30, 2008
    798
    46
    +107
    Code 1868 works all LG TVs on a rev9 sky remote.
  2. DeleO
    DeleO New Member
    Aug 22, 2012
    after trying countless other permutations, I used 0206 for my LG 42LG3000 and it worked like a charm. This was for a Sky+ vers 8 remote
  3. Miss Chief
    Miss Chief Active Member
    Jun 12, 2007
    7,544
    +1,088
    nice to see some of the LG SKY Codes 0206 1206 and 1293 are working for lots of people. These are the most common LG Sky remote codes available and work most LG TV's with a version 8 or 9 Sky Remote control.
  4. jono t
    jono t Member
    Mar 30, 2008
    798
    46
    +107
    The above codes do not work for 2012 LG smart tvs 1868 does.
  5. kaputchnik
    kaputchnik New Member
    Sep 27, 2012
    Hi when i press the select and red button together the red light does not blink twice like everyone says here - mine just stays on. So i cant programme my remote to work with my LG
    any ideas
  6. Hedgehog1979
    Hedgehog1979 Member
    Feb 28, 2009
    295
    +44
    Where did you get the remote, if it was from eBay it may be a clone RCU. They look just like the real thing but what you are explaining is a common tell that it's a clone.
  7. madmowerman33
    madmowerman33 New Member
    Oct 10, 2012
    I have a LG model number 32LS3500 but only had an old style Sky remote, but after running through all 3 digit numbers (quite sad that I had that much spare time on my hands) had absolutely no joy.
    I luckily just got a Rev 8 second hand remote from Ebay quite cheap. I found these numbers on another SKY remote code website and I tried the 1st number below, 0206. I am happy to report that it worked a treat.
    Note: LG Support supplied the following for Rev.8: 0206, 1293, 1665, 1174, 1176, 1219, 1280, 0857, 0851.
    Note: The LG codes that Sky have provided to work with newer LG television sets are;
    0037, 0056, 0060, 0065, 0080, 0081, 0125, 0137, 0178, 0191, 0204, 0244, 0245, 0275, 0318,
    0389, 0391, 0398, 0405, 0459, 0502, 0742, 1146, 1367. We also have some older codes;
    206, 037, 060, 065, 080, 137, 191, 244, 245, 275, 318, 389, 391, 398, 405, 459, 502.
    Hope these are of some help to others
  8. saeed3897
    saeed3897 Member
    Dec 24, 2012
    Code 0056 has worked on my LG TV. I had lost all hope till I found it on AVFORUMS>COM.
    Thanks members.
  9. spokes
    spokes Member
    Nov 5, 2009
    Revision 8 standard sky remote code that worked for me on the ps3000 was 0080 gives full control of tv with sky remote only thing that I can't get working is when tv is off an pressing the sky button on the remote will not turn the tv back on and I have tried tv/select+green button/channel #
  10. Miss Chief
    Jun 12, 2007
    7,544
    +1,088
    If you press TV then standby the TV should come back on. Don't forget to press Sky afterwards.
  11. spokes
    spokes Member
    Nov 5, 2009
    Thanks for the reply I should have been clearer I'm used to turning on my 50" Samsung with the sky button I was just trying to get the lg to work in the same way .. Also I did say you had full control of the lg with the sky remote with the 0080 code this is on the standard sky box not hd or plus boxes using rev8 remote ...
  12. HD sceptic
    HD sceptic Member
    Apr 1, 2009
    694
    28
    +71
    pressing the 'sky' button has never turned on either of my LG TV's, but the Thomson CRT I had years ago did.
    Not all manufacturers implement remote commands in the same way. Possibly your old TV was manufactured so that it turned on when it sensed the HDMI socket was receiving a signal (ie the sky box turning on) whereas your LG TV isn't built the same way
  13. spokes
    spokes Member
    Nov 5, 2009
    I've used the sky button to turn on all of my previous tvs granted none of them were lg (2 years old) I've always bought samsung as for the old tv it is just over a year old as its 3d still turns on with the sky button
