gIzzE
Exactly.
And that was my point, if you are only going to get your set out of the box and leave it at default settings why not just buy the cheapest piece of crap you can find.
It really is a case of cutting your nose off.
And then to question people and say you don't believe there are noticeable differences between sources when your display is so out of whack that you won't even notice those differences I just find insulting and extremely ignorant.
And to tell people that your set straight out of the box looks as good as a calibrated set just makes you look a bit silly imho.
Two C750 Samsungs, one reset to factory settings and one with me doing all the adjustments I can in 5 minutes, no calibration discs or anything, just turning off the processing that is designed to give artificial punch and setting the basic controls.
50 people from the forum and they can all judge blind which one gives the better results.
I would bet my house on the outcome of that one.
