Sky HD and Nikkai Remote Control IR Repeater
Discussion in 'Sky Forum' started by perrygascoine, Jan 17, 2010.
  1. perrygascoine
    perrygascoine Member
    Jan 17, 2010
    I have the Nikkai Remote Control IR Repeater which I purchased from Maplin just before Christmas and it worked wonderfully with my DVD player and my old Sky Plus box as these are kept in a wooden cupboard with solid doors.
    I have this week upgraded to SKY HD and the Nikkai Remote Control IR Repeater does not work despite me locating the receiver on a number of different places on the box. When I point my remote at the Nikkai Remote Control IR Repeater the red flashes but alas nothing changes on the Sky HD box.
    I have read on another forum that my Sky HD box may be sending via IRda rather then plain IR. If this is the case is there anything I can do to get it to send in IR or if not can anyone shed any light why my Nikkai Remote Control IR Repeater does not work with Sky HD.
  2. Daisybear
    Daisybear Member
    Oct 11, 2010
    Hi Perry,
    I just purchased the Nikkai Remote Infrared Repeater from Maplins to use with my Sky HD box and it doesn't work. Did you get any response to your post?
    Many thanks,
    Kelli
  3. jasonmark38
    jasonmark38 New Member
    Oct 3, 2010
    145
    +12
    It's a pity you didn't read post #1 first, you could have saved yourself the trouble! :D The Nikkai is not compatible with Sky HD boxes which use IRDA. Return it to Maplin, and ask them if they have one which is IRDA compatible (if they know what you are talking about)! :D If not, try elsewhere - ebay.co.uk or a google product search perhaps?
  4. logiciel
    logiciel Moderator
    Feb 2, 2008
    46,356
    +4,490
    Do you have chapter and verse for that, and if so why do they work with universal remotes that don't do IRDA?
  5. jasonmark38
    Oct 3, 2010
    145
    +12
    There are threads/posts about IR vs IRDA on Sky HD boxes all over this and other forums. A post by simonpoulton on sky user 09-09-10, 03:44 PM seems to explain it well (for video sender also read IR repeater).
    "I believe the remotes all output both IR and IRDA signals and certain boxes only work with IR and certain ones only work with IRDA. So the remote sends an IR and an IRDA signal to the video sender, video sender chucks away the IRDA one and sends the IR one box receives it and because it doesnt support IR doesnt respond."
    OneForAll universal remotes are made by Universal Electronics BV, who also make all Sky+ and Sky HD remotes. It would explain why their universal remotes work with Sky. There are other universal remote brands of course.
  6. davemurgatroyd2
    davemurgatroyd2 Active Member
    Dec 26, 2004
    7,216
    +1,102
    Have you tried changing the HD remote to Sky+ mode which should also work an HD box - don't know whether or not it will work via the video sender
  7. davemurgatroyd2
    Dec 26, 2004
    7,216
    +1,102
    That does seem very strange as all Sky remotes (after version 4 and some earlier ones as well) can be reprogrammed to operate any type of Sky box see here
    http://www.avforums.com/forums/sky-...ogram-standard-operate-sky-hd-vice-versa.html
  8. jasonmark38
    Oct 3, 2010
    145
    +12
    I believe this is because Universal Electronics BV incorporated the same IRDA capability into the Sky+ and Sky HD remotes which is used in many of their OneForall universal remotes.
    It only seems to be a problem when using some video senders and IR repeaters (usually Nikkai). From what I have read in these cases, trying a Sky+ remote instead of a Sky HD remote didn't work, presumably this is the same as setting a Sky HD remote to Sky+ mode.
    Also, I would like to know if it is possible to operate a Sky+ and Sky HD box in the same room, with 2 Sky HD remotes, 1 set to Sky+ only mode, and the other set to Sky HD only mode?
  9. jasonmark38
    Oct 3, 2010
    145
    +12
    An example of a video sender which is not IRDA compatible, and doesn't work with some Sky+/Sky HD boxes.
    2.4Ghz 2.4G Wireless Audio Video AV TV Sender Receiver on eBay (end time 15-Oct-10 15:08:01 BST)
    "Most Freeview boxes, DVDs, VHS, etc. remotes will work with this. The remote may not fully function with certain Sky+, Sky HD or Virgin+ set-top boxes. You can always send/receive the Audio/Video signal, but the remote relay for this item only functions with IR (Infrared) remotes and some of these Set Top Boxes use IrDA (Infrared Data Association) for their remotes, which means you wouldn't be able to use the remote control to change the channels from the receiving location. THIS IS NOT A FAULT and you should confirm whether your transmitter uses IrDA before bidding, or decide that if it does, whether you mind changing channels directly in the transmitter room rather than being able to use the remote from the receiving room."
  10. logiciel
    logiciel Moderator
    Feb 2, 2008
    46,356
    +4,490
    "why do they work with universal remotes that don't do IRDA?"
    Harmonys and others have no problem with any Sky receiver.
  11. davemurgatroyd2
    Dec 26, 2004
    7,216
    +1,102
    It will work on some remote and box combinations (works on my rev 8 remotes Sky+ and HD and Amstrad DRX890 but not on Thomson box)
  12. jasonmark38
    Oct 3, 2010
    145
    +12
    Many OneForAll universal remotes support IRDA, but there are other manufacturers. How do you know the Harmonys and others don't support IRDA? The ones that do will control all sky boxes, the ones that don't will only control some of them. The problem isn't with remotes, it's with video senders and IR repeaters which aren't IRDA capable.
  13. paris
    paris Member
    Sep 18, 2013
    Hi please some one help, I can't change channel on my receiver, I have bought nikkai and on my spare room tv pictures perfect and the remote works for the first 5mins only when everything is rebooted , then it stops working so I can't use the remote , iv bought sky + remote and sky hd remote both the same
    I can only use the remotemfor the first 5mins after rebooting
    Please help its driving me crazy
  14. John booth
    John booth Member
    Oct 10, 2013
    2
    I have the nikkai 5.8ghz sender and whilst yes it really drive me mad when I bought it I quickly realised it does work. Top picture transmitted but no remote signal. So I played around with it for ages and consulted this forum, IR & IRDA ?!? Works on new and old sky+ HD boxes (I have both) turn the antennas nikkai side out and point them at each other.... Simple. They antennas feel like they only go so far but won't rotate but they do click all the way round.
    If someone says IR & IRDA again on this forum I'm going to explode it's all rubbish rubbish rubbish!!
  15. Stevenage Neil
    Stevenage Neil Active Member
    Jul 14, 2008
    9,584
    +894
    Your middle name isn't Wilkes, and you didn't assassinate Abraham Lincoln did you? :D
  16. Tight Git
    Tight Git Active Member
    Mar 3, 2004
    6,321
    +605
    I wonder how many times he's been asked that! :suicide:
    Just ignore him, John.
    Well, the rest of us do! :laugh:
    (Oh, and welcome to the forum.)
  17. Stevenage Neil
    Jul 14, 2008
    9,584
    +894
    I would suggest that greater than 50% of the readers/contributors of this forum have just learnt something, given the standard of modern teaching. :hiya:
    • Thanks Thanks x 1
  18. John booth
    John booth Member
    Oct 10, 2013
    2
    If I google myself I do appear to be linked with Lincoln.
  19. Tight Git
    Mar 3, 2004
    6,321
    +605
    I've just Googled myself and I find I'm a talented musician! :D
    The things you can learn on line...
  20. Stevenage Neil
    Jul 14, 2008
    9,584
    +894
    Do you blow your own trumpet? :rotfl:
  21. Tight Git
    Mar 3, 2004
    6,321
    +605
    Nobody else will, but lets get back on topic before Logi wakes up! :smashin:
  22. logiciel
    logiciel Moderator
    Feb 2, 2008
    46,356
    +4,490
    I've been wide awake and watching this but you lost me on post #15!
  23. Stevenage Neil
    Jul 14, 2008
    9,584
    +894
    So you were included in Post#17? :laugh:
  24. logiciel
    logiciel Moderator
    Feb 2, 2008
    46,356
    +4,490
    Although fully acquainted with the life and works of James Wilkes Booth, yes!
