Sky HD and Labgear HDU681
Discussion in 'Satellite TV Forum' started by mcluma, May 9, 2013.
Thread Status:
Not open for further replies.
  1. mcluma
    mcluma Member
    Feb 27, 2012
    70
    +8
    I have a labgear HDU681 - which has 8 tv distribution outlets on them, but that is not big enough for me
    I have added another 8 tv points, so in total 16,
    is there a way to extent the HDU681 to 16 outlets
    what is out there that helps me distribute the signal over 16 tv points, but still allows me to distribute CCTV - Sky uplink - DAB - UHF and allows me to use the sky-eye
    Satalite is directly link to the skybox, and not to the HDU681
  2. logiciel
    logiciel Moderator
    Feb 2, 2008
    46,079
    +4,477
  3. mcluma
    mcluma Member
    Feb 27, 2012
    70
    +8
    That one doesn't have CCTV input
  4. logiciel
    logiciel Moderator
    Feb 2, 2008
    46,079
    +4,477
    That was the first 16-way that came up on a Google search.
    Their own site will tell you whether they have an exact equivalent of the one you have now.
  5. pedro2000uk
    pedro2000uk Active Member
    Feb 20, 2009
    3,754
    +599
    The CCTV input is nothing more than another RF in but you can add one (if you need another) by just looping through an RF modulator either stand alone or one in a device.
    You could take one of the outputs & feed another 8 way rf dist' amp with one higher power output & add a splitter to that higher power output to make 16.
    Don't like doing that but it will work.
  6. logiciel
    logiciel Moderator
    Feb 2, 2008
    46,079
    +4,477
    The CCTV input could combine with another input through a 99p combiner.
    I don't like that either but it would (probably) work.
  7. MartinPickering
    MartinPickering Active Member
    Sep 23, 2009
    4,533
    +461
    Take a look at the Global Amp Adder.
  8. mcluma
    mcluma Member
    Feb 27, 2012
    70
    +8
    I have now used the hdu681 and msa 2123 this works good
    However
    I noticed that for the sky eye to work you not only need the uplink to the 681 from the sky box but also the downlink form the 681 to sky
    The issue is i didn't pull that cable ,i thought that only the uplink would be enough
    But as i understand the uhf signal for the distribution comes via the downlink which and the uplink
    Is there a way to get the sky eyes to work with just one cable and the rooms use the uhf from the 681
  9. logiciel
    logiciel Moderator
    Feb 2, 2008
    46,079
    +4,477
    That is obviously incorrect.
  10. mcluma
    mcluma Member
    Feb 27, 2012
    70
    +8
    I did read it somewhere
    Just to clarify i'm not using rf1 on the sky box
    The dish is directly connected to the sky box
    Rf2 is connected to the 681
    Antenna signal is connected to 681 uhf
    So the sky eyes should work via sky upload????
  11. winston2010
    winston2010 Member
    Jun 28, 2010
    1,405
    63
    +121
    Yuk. 99p combiners are plastic, unscreened, and probably resistive and lossy.
    Make it £5-99 and get something decent.
    Maplin Electronics
  12. mcluma
    mcluma Member
    Feb 27, 2012
    70
    +8
    Found a Triax UHF Combiner 340110
    [​IMG]
  13. winston2010
    winston2010 Member
    Jun 28, 2010
    1,405
    63
    +121
    That is not a UHF combiner, it is a satellite/TV combiner. Won't work for what you want.
  14. mcluma
    mcluma Member
    Feb 27, 2012
    70
    +8
    This is probably an open door situation to a lot of people here, but as it isn’t working for me, I put it out here.
    I have a sky HD box and a HDU681 splitter/distributer
    Sky is in the lounge the HDU681 in the loft.
    TV in lounge receives signal via an HDMI cable directly from the sky box plus a coax cable from the HDU681 – Used for freeview
    The RF2 from the sky box is connected via a coax to the HDU681 (uplink in)
    The skybox is located in an enclosed cabined
    HDU681 Switch is on UHF & CCTV
    HDU681 is connected via UHF in to an outside aerial
    I would like the eye to work on all 8 outlets (in the lounge I can operate sky via the eye)
    But it isn’t working
    Does sky need an aerial? –and is the HDU681 switch in the correct position
    Many thanks for the advise/help
  15. mcluma
    mcluma Member
    Feb 27, 2012
    70
    +8
    Is the maplin you showed not a uhf combiner too? - bit confused here. i thought the only difference is the connectors
  16. logiciel
    logiciel Moderator
    Feb 2, 2008
    46,079
    +4,477
    With the RF2 Out connected to the Triax it should send the channel one way and the remote control back the other.
    A Sky machine does not need an aerial, and I don't understand "in the lounge I can operate sky via the eye".
  17. winston2010
    winston2010 Member
    Jun 28, 2010
    1,405
    63
    +121
    Yes, the Maplin one IS a UHF combiner. The Triax one IS NOT, it is a SAT TV combiner, it is written on the case.
  18. mcluma
    mcluma Member
    Feb 27, 2012
    70
    +8
    I got probably confused as it says on the triax website that this is a VHF - UHF / SAT Combiner
    so it could be used for all of the above
  19. mcluma
    mcluma Member
    Feb 27, 2012
    70
    +8
    The skybox is in a unit, the infra-red port is not visable, therefore by using the eye i can still operate the sky.
  20. winston2010
    winston2010 Member
    Jun 28, 2010
    1,405
    63
    +121
    NO. It is to combine sat on one input with VHF/UHF on the other.
  21. mcluma
    mcluma Member
    Feb 27, 2012
    70
    +8
    An aha moment
    I see it
    Thanks for being patient with me
  22. mcluma
    mcluma Member
    Feb 27, 2012
    70
    +8
    Ok another issue solved
    Was able to get the sky eye to work was an issue of two things
    A wrongly coded wires in the loft (the upload cable was wrongly coded)
    B a dodgy /duff cable between rf2 and the wall plate
    Thanks for all the help
Thread Status:
