self adhesive cable clips
Discussion in 'Cables & Switches' started by ben_e71, Jan 19, 2009.
  1. ben_e71
    ben_e71 Member
    Jan 21, 2003
    200
    +6
    I'm sure I haven't dreamt it but I am looking for some cable clips that are basically a small square of plastic with a self adhesive backing and a loop on the top that allows you to cable tie cables along the underside of a desk for example.
    Anyone know if they exisit and if so where I can get them - done a google to no joy
    thanks
  2. treaclesponge
    treaclesponge Member
    Jan 9, 2009
    58
    +6
  3. ben_e71
    ben_e71 Member
    Jan 21, 2003
    200
    +6
    sort of but not quite- - -should do job though
  4. treaclesponge
    Jan 9, 2009
    58
    +6
  5. ben_e71
    ben_e71 Member
    Jan 21, 2003
    200
    +6
    thanks that's them
  6. Holdfast
    Holdfast Member
    Jan 11, 2010
    Another good option for people with this requirement are 3M's "command Adhesive small cord clips".For cable diameter 5mm. Product code: 17302.
  7. mrbenn
    mrbenn Member
    Jan 16, 2009
    682
    +97
