Hi i am a complete novice. Just purchased a panasonic with built in freesat receiver. I would like to be able to watch sporting events from around teh world but not with SKY subscription.
What is the best satelite system to buy and hwo much would i expect to pay with installation.
Shab12
this question is possibly the most asked and therefore most commented on , suggest you read through some threads and you will find all the answers you need.
Hi and welcome to the forum.
It's usual to buy a receiver and a dish separately.
The receiver could cost from fifty pounds up to several hundreds.
You could receive from two or three satellite groups with a fixed dish, and from many more with a dish that has a motor to move it around.
A fixed dish and its installation might cost from £75, a motorised one up to £250.
There are some free channels, and subscriptions to channel "packages" are available, from £100 to well over £1000.
As Dan said there is a lot of detail on the forum, and a Google search will find you suppliers for the equipment, while the local Yellow Pages should find you companies to quote for the installation.
Shab12
If you want the best .. that usually starts nowadays with a decent motorised system, it depends how big a dish you go for... they go from c. 45cm to over 3m [or bigger] but a popular size is a decent 1m motorised system & it depends on where in the UK you are how much it will get- the further south you are the more you get. Costs for decent gear properly installed are just shy of £300 ex receiver & it also depends if it has to go over a roof to get the satellite arc that usually adds to it.
The best receiver is usually a choice between a Linux receiver & non LInux receiver/ HD/ twin tuner/ clone or original ..
One you'd call 'the best' based on a c. 1m dish could be over a £1000 complete & a few go for bigger dishes that can be 1.2m, 1.8m, 2.4m or whatever costing up to £2500 [just for the dish]
It really depends where you draw the line at 'the best' but you can get a decent system complete for c. £450.
