Samsung won't auto store channels in uk
Discussion in 'LCD & LED LCD TVs' started by Lambo mad, Jun 28, 2009.
  1. Lambo mad
    Lambo mad Member
    Jan 5, 2009
    234
    +16
    Please help me
    I have a Samsung LE40A557P2FXXU and i've tested the aerial in other TV's and they pick up all the freeview channels but my Samsung won't find any
    I'm in the UK
    My dads ****** £100 bush found them all but a £600 samsung refuses
    All the other inputs work fine i.e xbox, PC and DVD
    Any ideas??
    I'm about to drop it out of the window :mad:!!
  2. Adrian_F
    Adrian_F Active Member
    Jun 29, 2007
    1,410
    83
    +304
    Have you selected DTV ?
  3. Lambo mad
    Lambo mad Member
    Jan 5, 2009
    234
    +16
    I click it on the remote and it says not available
  4. Adrian_F
    Jun 29, 2007
    1,410
    83
    +304
    Try a first time installation again and make sure that you choose United Kingdom as the country.
  5. Lambo mad
    Lambo mad Member
    Jan 5, 2009
    234
    +16
    Have done that too =(
    Still no channels
    It's as if the aerial's not even plugged in
    I tested the aerial leads and the socket with the bush and that picks up everything freeview and analogue
  6. mray
    mray Active Member
    Feb 16, 2004
    2,621
    83
    +216
    You should have the TV tuned to the DTV input, then select plug & play on the menu and you will be guided through the tuning process.
    Apologies if you've done this already.
  7. Lambo mad
    Lambo mad Member
    Jan 5, 2009
    234
    +16
    How do i tune to the dtv input
    And my apologies because i am an idiot
    I've tried the plug and play and it goes through but can't pick any up
  8. mray
    mray Active Member
    Feb 16, 2004
    2,621
    83
    +216
    Press the DTV button near the top of the remote.
    One or two presses for DTV/Analogue.
    If you're tuned to the channel that says "unavailable", then you are already on it, but that is the one you need.
    Is your aerial plugged directly into the TV? Or through a DVD recorder?
  9. Lambo mad
    Lambo mad Member
    Jan 5, 2009
    234
    +16
    Yes the aerial is direct and it says not available when i click that button
    By the way thank you very much for helping me through this
  10. mray
    mray Active Member
    Feb 16, 2004
    2,621
    83
    +216
    No problem, but have you tried running Plug&play when tuned to this channel?
    I found the tuner in my A656 to be very good, so if it's not picking up anything, maybe it's faulty.
  11. Lambo mad
    Lambo mad Member
    Jan 5, 2009
    234
    +16
    Yeah i've tried.
    Still nothing being picked up
    I may try plugging my old n64 in the aerial and see if that is picked up
    If not i'll ring samsung and hopefully they will send someone round if i'm still within warentee
  12. mray
    mray Active Member
    Feb 16, 2004
    2,621
    83
    +216
    Did your Dad's Bush pick up the channels in the same location as your Samsung? If not, maybe you're in a weak signal area.
    Good luck with finding a fix. :thumbsup:
    Sorry. From your earlier post, it looks like they are in the same place!
  13. Lambo mad
    Lambo mad Member
    Jan 5, 2009
    234
    +16
    yeah they were side by side, same socket, same leads
    It won't find a playstation through the aerial socket either so it looks like it's either a simple option i'm not seeing or it's a faulty tv
  14. Adrian_F
    Jun 29, 2007
    1,410
    83
    +304
    Can you select DTV then D.Menu on the remote and try scanning from there ?
    If not you could try to reset option in the service menu, from Standby...
    Info-Menu-Mute-On and choose reset. Do not alter anything else !
  15. Lambo mad
    Lambo mad Member
    Jan 5, 2009
    234
    +16
    Unfortunately tried that as well
    A service engineer is comming tomorrow so i'll post up here what the problem was so if anyone else encounters it, it will be explained
  16. Lambo mad
    Lambo mad Member
    Jan 5, 2009
    234
    +16
    sorted within seconds
    There was an option within the service menu that needed to be changed
    It's a setting called ready
    It was set as on when it needed to be set as off
    Simple as that
    • Thanks Thanks x 2
  17. mray
    mray Active Member
    Feb 16, 2004
    2,621
    83
    +216
    Hi.
    Good to see you got it sorted! :smashin:
  18. Lambo mad
    Lambo mad Member
    Jan 5, 2009
    234
    +16
    Thank you for your help
    I never would have figured that out if it weren't for Samsungs AMAZING customer services though.
    AND they were all English on the other end of the phone :D
  19. squiz
    squiz Member
    Sep 3, 2010
    I have almost identical problem so where was this ready on/off option?
  20. NRmedia
    NRmedia Member
    Oct 17, 2010
    428
    28
    +31
    Hi, I'm having the same problem too... not picking up any digi channels!
    I cant see a "Ready" setting in the service menu either.
    Any help would be appriciated.
  21. Away
    Away Member
    Mar 9, 2011
    Hi....
    My samsung tele decided to not pick up any digital channels this morning...have tried factory restore...auto store etc...but still nothing...
    the 'ready' setting is coming up as failure...could this be a problem?
    Any help would really be greatfullll....thank youu
  22. FritzFantom
    FritzFantom Member
    May 4, 2011
    For receiving DVB-T -- is an external antenna required? I do have the SyncMaster FX2490HD.
