Samsung R86/87/88 Owners Thread, ~Settings/Discussion *Part 2*
Discussion in 'LCD & LED LCD TVs' started by RottenFox, Dec 14, 2008.
  1. RottenFox
    RottenFox Moderator
    Mar 11, 2006
    16,816
    +4,149
    • Thanks Thanks x 3
  2. scotty2809
    scotty2809 Member
    Sep 12, 2008
    11
    dibs to be 1st to post....as everyone will now be looking at this thread rather than the 'part 1'
    The question:
    right ive always wondered this, just thought maybe someone could clear this up for me. I have my samsung connected via hdmi to my pc as well at its native res, now for xmas im getting a blu-ray optical drive for the pc and wanted to know if i play a blu-ray film from my pc onto the samsung it self, will it be true 720p as its running at the resolution from the PC rather than say a direct blu-ray player would output over 720p/1080i/1080p. Would i in affect need to change resolution to a height of 720 pixels in order for this to be 'true' HD or would simple the software that is supplied (PowerDVD HD i think?) do the scaling process etc? thanks, Scott.
  3. kendo88
    kendo88 Member
    Nov 30, 2007
    209
    +7
    My TV has stopped responding to my remote. When i press a button the red light on my R88 blinks, but nothing happens, what can i do?
  4. PaddyRamsey
    PaddyRamsey Member
    Jan 5, 2005
    20
    Can anybody tell me what version of HDMI this telly has? Is it 1.3?
  5. chenks
    chenks Member
    Aug 18, 2007
    152
    +3
    does anyone know if you can change/adjust the overscan on the LE32R87BD in the service menu ?
    i am trying to set up the TV using the BBCHD test card and i'm missing quite a bit from the sides.
  6. Yemeth
    Yemeth Active Member
    Jun 5, 2007
    5,062
    +1,047
    If you're connected via HDMI #2 or VGA, than the picture wont fill the 1366x768 screen of the tv at 720p, due to 720p being 1280x720. But if your sending a standard progressive/interlaced, the tv will do the processing and scale it to fit the screen at 720p, provided you choose Just Scan in the HDMI options.
    Try disconnecting the tv from the power socket, then turning it back on.
    Version 1.2.
    If you're running the test card via HDMI, just choose Just Scan in the options and you should be getting the full pic without overscan.
  7. chenks
    chenks Member
    Aug 18, 2007
    152
    +3
    where is that? in the service menu or normal user config menu ?
  8. Yemeth
    Jun 5, 2007
    5,062
    +1,047
    Press MENU, then enter the pic adjustments section (where the contrast etc. is). Then go down until you find 'Size'. One of them is Just Scan. Alternatively, you can keep pressing the P.Size button at the bottom of the remote control to browse through all the size options until you get Just Scan.
  9. chenks
    chenks Member
    Aug 18, 2007
    152
    +3
    ok sorted... that is now showing all of the test card.
  10. chenks
    chenks Member
    Aug 18, 2007
    152
    +3
    hmmm... i'm find that with using the "just scan" option, it is actually over adjusting it.
    on some channels i am now getting a small/thin black area on some of the sides that i didn't have before.
    it's as if it has over compensated the over scan and took it took far. it's quite noticeable on sky sports news.
  11. Yemeth
    Jun 5, 2007
    5,062
    +1,047
    Just Scan is the in-built process of mapping the signal as close to a 1:1 pixel ratio as possible.
    My knowledge in tv broadcasts is limited, but it could be due to the HD broadcasts being 720p (1280x720) in relation to the panel's 1366x768. Despite this, the signal should be filling the screen in Just Scan. Is this for all channels or just sky and a select few? How wide are the black lines? Top/bottom or the sides?
    See how much 16:9 differs from Just Scan. If it's acceptably larger to a point that there is no significant cropping, you may want to keep it as 16:9.
  12. chenks
    chenks Member
    Aug 18, 2007
    152
    +3
    the HD channels fit the screen perfectly.
    it's channels like Paramount, sky sports news, E4 etc, that now have a little black at the left/right sides (and sometimes at the bottom).
    as a comparison, with 16:9 mode the DOG for HistoryHD is touching the top of the screen, in JustScan mode, the DOG much lower (as i think it should be).
    it's as if the JustScan mode in non-HD channels is over compensating to the stage where it is actually under-scanning.
  13. Yemeth
    Jun 5, 2007
    5,062
    +1,047
    It makes perfect sense if the non-HD channels are the ones with borders. Its because just scan is trying to map a significantly 'lower than 1366x768' signal to its screen. Obviously mapping 1:1 a small resolution onto a larger resolution screen will result in the 'letterbox' effect. (e.g. a 16:9 signal on a 16:10 monitor).
    IIRC one of the settings is Auto Wide in the pic size options, see how that option fares. Also, check if there's something related to it in the options of the box itself.
    Sky or Virgin?
  14. chenks
    chenks Member
    Aug 18, 2007
    152
    +3
    it's sky.
    the non-HD channels aren't showing in "letterbox" though.. the black spaces are at most only 0.5cm (if even that).
  15. Daniel Duerden
    Daniel Duerden Member
    Oct 25, 2008
    3
    I find that when I turn 'movie plus' on, say for a games console. It stays on for all the other components. i.e. when I switch back to TV 'movie plus' is still on - but I didn't set it to be on for that component.
    can anyone help?
  16. Yemeth
    Jun 5, 2007
    5,062
    +1,047
    Thats it?! Surely 0.5cm isnt a problem. Make sure you're box settings are 720p or 1080i, not Automatic.
    Ideally, you'd never need to put Movie plus on (I know I dont).
    Also, IIRC that issue plagued the M8 series, not the R8 series.
    For a games console, turn Game Mode on instead of movie plus.
  17. chenks
    chenks Member
    Aug 18, 2007
    152
    +3
    i know it doesn't sound a lot, but it does result in having weird white and black dashes appearing at the very top on some channels, which can be quite distracting when viewing.
    i have my box set to 1080i.
  18. Yemeth
    Jun 5, 2007
    5,062
    +1,047
    Try posting this as a general Sky HD query in the Sky HD forum rather than an LCD query, hopefully people with more knowledge than me can help you. I dont know how else to remedy the situation as i dont have Sky.
  19. Keegz
    Keegz Member
    Dec 25, 2008
    Hi there, I have this strange problem with my R88, when I have the movie plus on wierd things happen, its quite hard to explain but for example: when there is a thin black line in front of a bright backround the line will flicker going transparent. Then when I turn the movie plus off it stops this problem but causes quite alot of motion judder on slow moving scenes. Any help would be appreciated.
  20. vallumlj
    vallumlj Member
    Oct 19, 2007
    192
    Hi do i set the tv so sky hd starts every time instead of me having to go through all the source options
  21. carlosamp
    carlosamp Member
    Dec 26, 2008
    2
    what are the default settings of the following options?
    Dynamic Dimming:
    Dynamic Contrast:
    Dynamic CE:
    thx in advance
  22. Vinterbird
    Vinterbird Member
    Jan 6, 2008
    17
    Party 1 says that entering the Service Menu will void the warranty, but my TV has been having some problems, and I now need to send it in for repairs.
    Will the Samsung reapir shop be able to tell that I've entered the service menu, and what should I do in this case? Just though luck?
  23. ll Deano ll
    ll Deano ll Member
    Oct 3, 2007
    375
    28
    +28
    I don't think that is true.
    I've recently sold my Samsung but when I had it and had a problem (or so I thought) the guy told me how to go into the Service Menu whilst on the phone to him at Samsung so I wouldn't say that it voids the warranty otherwise he wouldn't of told me to do it.
  24. chenks
    chenks Member
    Aug 18, 2007
    152
    +3
    mine does it on its own. i didn't need to do anything to make it do it.
    SkyHD is connect to HDMI2 on my tv and it's always on that when i turn the TV on (unless of course i had it on another source when i turned it off).
  25. chenks
    chenks Member
    Aug 18, 2007
    152
    +3
    samsung support told me that going into the service menu could invalidate the warranty.
  26. ll Deano ll
    ll Deano ll Member
    Oct 3, 2007
    375
    28
    +28
    'could'
    The guy told me how to go in there etc and if that was the case then surely he would have told me 'if you do this, if you do that' kinda thing.
  27. chenks
    chenks Member
    Aug 18, 2007
    152
    +3
    i'm not calling your a liar, i'm just telling what i was told.
    in fact, i still have the email and it's not "could" as i first thought....
  28. ll Deano ll
    ll Deano ll Member
    Oct 3, 2007
    375
    28
    +28
    No, I know you aren't.
    Also just saying what I was/wasn't told. :thumbsup:
    Well either it does void the warranty or Samsung don't care about there customers because I wasn't told it voids the warranty.
    What happened was that I started to see the previous picture shown on the TV when changing to another one so phoned them and he said 'are you with the TV now' I replied yes then he told me how to get into the Service Menu and said NOT to change anything then said to reset it.
    We cannot advise how to adjust settings within the service menu
    as this voids the warranty
    You're quote also seems that it voids the warranty IF you change settings.
  29. chenks
    chenks Member
    Aug 18, 2007
    152
    +3
    if i was to take a guess, i would pick the latter.
    guy probably just wanted you off the phone. i bet if someone had went wrong, he would have denied ever telling you to do it.
  30. degu08
    degu08 Member
    Dec 6, 2008
    17
    I've got a 'Samsung LE32A457' and the component setting for the xbox360 in 'part 1' really don't ook that good on thsi tv...any recommendations?
