samsung PS42Q96HD plasma - help on settings
Discussion in 'Plasma TVs' started by markgallagher, Aug 5, 2007.
  1. markgallagher
    markgallagher Guest
    just bought new samsung plasma t.v ps42q96hd, i am using it through an old sky box and would be very greatful if someone would tell me the best settings for this t.v, and the best way to look after it generally. i would be much apreciated. thanks Mark.
  2. tobyfield
    tobyfield Member
    Jul 26, 2007
    178
    +18
    There are recommend run in settings and they can be found at http://www.avforums.com/forums/showthread.php?p=5248896#post5248896.
    After that, it comes down to personal preference and lighting in your room. Make sure you have a decent scart lead, plugged into the RGB scart socket on the TV and the sky box set to RGB.
    Hope this helps.
