Samsung HT-THX22 - Repair or Replace?
Discussion in 'All-in-one Systems' started by contemptx, Oct 21, 2010.
  1. contemptx
    contemptx Member
    Dec 30, 2007
    37
    I currently have a Samsung HT-THX22, I have only used it a handful of times however the unit now cuts out after being used for a short period of time.
    Its not heat related as I have even placed a laptop cooling fan underneath and this also happens when its stone cold.
    However moving swiftly on to my question ;)
    What would you recommend.
    1. Have the unit repaired? (unknown cost)
    2. Replace the unit with a newer samsung model & keep the speakers?
    3. Replace the unit with another setup & keep the speakers?
    4. Replace everything for another setup.
    Here are also a few little pieces of hardware I have been looking at.
    Blu-Ray Player - Sony S370 / S3570
    Media Player - HDI Dune / PCH / Mede8er
    Music - Sonos Z90
    so do you think I would be best to go for option 4 & replace everything for another setup?
    Thanks in advance for your response ;)
