Samsung Anynet Problems?
Discussion in 'All-in-one Systems' started by Speedyr369, Dec 30, 2008.
  1. Speedyr369
    Speedyr369 Member
    Dec 30, 2008
    10
    I am a real newbie to surround sound and have been trying to get my new Samsung HT TX315R all setup and working.
    One of the problems I have is this anynet shenanigans as it is forever turning the tv unit on when I just want to listen to a cd and constantly turning on the surround sound when I just want to watch the tv.
    Have I got this setup incorectly or is it intended to do this?
  2. RottenFox
    RottenFox Moderator
    Mar 11, 2006
    16,960
    +4,243
    switch anynet off, its a pain in the rear.
    if you want multi item functionality then the best bet is to buy a remote like a harmony,which is a far better step than using hdmi control(which never works as people want).
  3. Speedyr369
    Speedyr369 Member
    Dec 30, 2008
    10
    Many thanks for the reply, I will flick through the options to turn it off. Multifunctional remotes dont bother me so not a problem.
  4. Minimia
    Minimia Member
    Nov 25, 2007
    17
    I'm going to totally disagree with this. I have a really good Harmony remote, all programmed up for my Samsung TV, Samsung receiver, and Sky HD box. At best it is kinda OK.
    It is actually loads better to hit 'Power' on my Samsung TV control (this turns on tv and receiver, and sets them both up correctly. After this, I use my Sky+ remote to control everything, channel changing,volume etc.
    The Harmony has sat unused in the drawer for a long time now. Native controls > third party controls.
  5. RottenFox
    RottenFox Moderator
    Mar 11, 2006
    16,960
    +4,243
    play, stop , fast forward, rewind, previous/next track, settings, etc..
    mulitple items controlled are they,backlighting switched on..???
    harmony/universal remote is still the best for multiple items.
    and why you thought the need to dig up a 6 month old thread is mystifying.
  6. Minimia
    Minimia Member
    Nov 25, 2007
    17
    Well, I have both, and I prefer to use the native remotes than the Harmony.
    But hey, we can have different opinions
    I wasn't aware of the statute of limitations on posting. I was just posting on a 6 month old thread because it may save someone blowing £70 on a Harmony remote that some would regard as a bit of a PITA.
    Actually, I've just changed my mind totally!!! Harmony univerals are teh best thing evar!!!
    Anyone want to buy a very lightly used one?:D
  7. RottenFox
    RottenFox Moderator
    Mar 11, 2006
    16,960
    +4,243
    £70 on a harmony..you can get a 525 for around £30 or less if you hunt around..
  8. p101chap
    p101chap Member
    Oct 20, 2007
    49
    I have the same problem speedy, (i have a sammy tv & home cinema-i thought id keep it the same but I would have been better of buying a different equipment) Anynet can be usefull, but why anyone would want the bloody tv switched on, when you want to listen to the radio/cd is beyond me. The only work around is to switch anynet on/off all the time. its a pain.
