samsung a656,b550 srs trusurround xt/hd help
Discussion in 'LCD & LED LCD TVs' started by Photomg, Jul 8, 2009.
  1. Photomg
    Photomg Member
    Jul 8, 2009
    2
    Hi All,
    reading the info on srs trusurround it converts 5.1 and 7.1 sources
    into a simulated surround through 2.1. My confusion is what is the best way
    of sending a source from a ps3 bluray to the tv. If I select 5.1 pcm or 7.1pcm
    i have missing audio through the tv.( with srs on) the only way I get full audio is in 2.1 pcm which defeats the point of srs. Am I missing something?
    Looked on the web and I cant find any info on this , other than sites showing
    srs technology none seem to show you how to set it up. I'm just about to recieve a b550 for another room which has srs hd , as opposed to srs xt
    will things be just the same?
  2. Photomg
    Photomg Member
    Jul 8, 2009
    2
    Just thought I'd post this as no one else seems to know, after trying all the options 7.1 linear pcm 44.1 works with the tv and srs trusurround
    anything higher than that on the khz leads to missing tracks in the
    audio. At Least it works now
    http://www.avforums.com/forums/images/smilies/smile.gif
