Sagem DTR94250S. How to reset the forgotten Parental Code?
Discussion in 'Freesat Forum' started by ehonda, Aug 7, 2010.
  1. ehonda
    ehonda Guest
    Hi all.
    I have the mentioned above Sagem DTR94250S Freesat recorder. The problem is that it was set to other Parental Code then the original one (1234) and now we can't remember it.:mad:
    I can't get to any of it's settings without entering the code. Is there any way to reset it back to the factory defaults?
    Thanks for your help.
    Kev.
  2. domnal
    domnal Member
    Aug 14, 2010
    2
    Phone Sagemcom during the week on 08450 900 316
    and give them loads for not giving this advice on line and not having a weekend service !!
    You can always ask them how to re-set your code !!
  3. Gorgo
    Gorgo Member
    May 12, 2008
    4
    just phoned sagem and the default code to overide the existing parental code is 0044 hope that helps :)
  4. domnal
    domnal Member
    Aug 14, 2010
    2
    Thanks !!! :thumbsup:
