Rocksmith 2014
Discussion in 'Xbox 360 Music Games' started by Goooner, Sep 23, 2013.
  1. bilbosmeggins
    bilbosmeggins Active Member
    Jan 10, 2010
    2,415
    116
    +557
    The lead will help with lag, and enable you to send the signal to a better option than tiny telly speakers. It won't help with the buzzing as that is emanating from the guitar. When you say it starts buzzing as soon as Rocksmith has loaded a song, all that is telling you is that RS has selected a particular "tone" for that song. Depending on how high-gain that tone is will reflect upon how much buzzing you get. If you're playing a metal-type song then expect ultra high-gain plus loads of buzzing. As stated earlier, the buzzing diminishes as the quality of the guitar rises. Plus, chuck in single-coil or humbuckers into the mix. That's why I suggested maybe seeing if you could try another guitar, to put your mind at rest. And then there are good leads and bad leads too, lol.
    • Thanks Thanks x 1
  2. chewyx
    chewyx Active Member
    Feb 6, 2007
    1,831
    +345
    nope xbox.
    Do amps have toslink connections? Could i connect up with that instead of buying another cable (not that £1.59 is going to break the bank but i have a spare 5 metre toslink cable i could use)
  3. Goooner
    Goooner Well-Known Member
    Jul 23, 2005
    19,434
    +2,410
    No, some have 3.5 connectors for mp3 input, but mostly just 3/4".
    • Thanks Thanks x 1
  4. bilbosmeggins
    Jan 10, 2010
    2,415
    116
    +557
    Do you have an av amp or a half-decent stereo you could bang it through? For Rocksmith purposes I whack my guitar through a decent iPod dock, which sports a 3.5mm aux in. It sounds great.
    • Thanks Thanks x 1
  5. chewyx
    Feb 6, 2007
    1,831
    +345
    ive got a couple of amps but not one in the room where the xbox is. I could connect up to one if needs be though.
    Volume isnt a problem, the TV speakers are actually pretty good. Its more being able to hear what im playing as i have to turn the guitar right down in th emixer to avoid the feedback/buzzing. If i can suss that out it will be fine.
    Dont think a guitar amp is going to help either by the sounds of it. I need to try and solve the buzzing problem (and no not yet before any of you suggest a new guitar!)
  6. bilbosmeggins
    Jan 10, 2010
    2,415
    116
    +557
    Maybe you could make sure that the guitar volume knob is full up when you initially calibrate it in the tuner section, and then just throttle the knob back a bit during play. Shouldn't need the emixer tool that way.
    • Thanks Thanks x 1
  7. Goooner
    Jul 23, 2005
    19,434
    +2,410
    DLC hint for next week from Paul Cross via twitter
    and next week is super awesome! People are gonna go nuts!
    trust me. It'll be more than ace. ;-)
    Lots of speculation it's Ace Of Spades and a Maiden 5 pack, but we've been down this road before and got a Fallout Boy 5 pack and Nickleback :rotfl:
    We shall see.
  8. RobbySpurs
    RobbySpurs Active Member
    Feb 23, 2004
    1,849
    +406
    I am not so sure a Maiden pack would be good news after the SOTW...
    • Like Like x 1
  9. Goooner
    Jul 23, 2005
    19,434
    +2,410
    Specualtion moving towards Kiss now, as there's a guy called Ace in Kiss, apparently.
  10. Beximus
    Beximus Member
    Jan 19, 2010
    1,466
    +239
    Ace Frehley
    Could be totally off the wall and be something by Ace - How Long, or something like that?
  11. chocobear
    chocobear Member
    Jan 17, 2012
    336
    +75
    I'd really like some biffy clyro in the future but not sure how likely that will be. Any of you guys like them?
  12. chewyx
    Feb 6, 2007
    1,831
    +345
    Its an Ace of Bass 3 pack
    All that she wants
    The Sign
    Dont Turn around
    you heard it here first!
    • Like Like x 1
  13. chewyx
    Feb 6, 2007
    1,831
    +345
    would love some but I guess its rather unlikely.
    Id like some more artic monkeys, green day and of course some more foos
  14. Beximus
    Beximus Member
    Jan 19, 2010
    1,466
    +239
    I like them. Would be pleased to see some Biff - maybe The Golden Rule or Bubbles.
    :eek: I'm there!
  15. BigTone
    BigTone Active Member
    Feb 11, 2003
    1,658
    +313
    Arcade Fire for me, sounds like its not too tough :)
  16. bilbosmeggins
    Jan 10, 2010
    2,415
    116
    +557
    Looks like my bill for DLC will be quite small this week then :)
  17. tylerjosh
    tylerjosh Well-Known Member
    Apr 16, 2004
    5,664
    +808
    It's kiss
    Love gun
    Strutter
    Detroit rock city
    Crazy crazy nights
    I was made for lovin u
  18. RobbySpurs
    Feb 23, 2004
    1,849
    +406
    Is this confirmed/speculation/wishful thinking?
    Detroit Rock City would be good...
  19. tylerjosh
    Apr 16, 2004
    5,664
    +808
    Well as it's Ace and ACE was the guitarist in said band that's my inspired guess
    So I'll either look completely marvelous or a right tit
    I know which it'll be :)
    • Like Like x 1
  20. tylerjosh
    Apr 16, 2004
    5,664
    +808
    I'm not a big Kiss fan although a couple tracks would ok
    I guess there'll be a 5 pack
    And a 5 pack for around a month
    Maybe. Iron maiden, weezer, leppard and led zep. I added that in case anyone from zep is reading this thread and feels sorry for us
  21. chewyx
    Feb 6, 2007
    1,831
    +345
    in that case i'll chip in too. just in case.
    They said they wouldnt allow their songs on plastic instruments so you never know!
  22. Hugh
    Hugh Active Member
    Mar 31, 2003
    1,318
    +269
    Back to the days of 3,2,1 and dusty bin with dodgy verbal connections.
    In a Ted Rogers voice.
    "We said it'd be more than Ace. If you go phonetically, then more than aayycceee would be aayyycceeedeeeccceeee. Yes, you've won tonight's star prize. A 5 pack DLC from AC/DC."
    I can dream, can't I? :laugh:
  23. bilbosmeggins
    Jan 10, 2010
    2,415
    116
    +557
    I'm not a devout, religious type of chappie...... But I'm so praying that you are wrong :devil:
  24. Goooner
    Jul 23, 2005
    19,434
    +2,410
    Someone on the forum came up with the exact same logic, bit of a stretch :D
  25. RobbySpurs
    Feb 23, 2004
    1,849
    +406
    Using similar but completely different logic "MORE THAN ace" is the first two words of More Than Words which is an Extreme song, so therefore it is obvious to all that it will be an Extreme pack.
    Of course as much as I would like to see some Extreme songs they are likely to be as impossible, if not more so, than the Trooper...
  26. chewyx
    Feb 6, 2007
    1,831
    +345
    actually i think you'll find that the phrase "more than ace" has at least 2 letters from the word maggot in it.
    This therefore must mean that the DLC is clearly
    Goldie Looking Chain
    Guns dont Kill People
  27. BigTone
    Feb 11, 2003
    1,658
    +313
    To be 'more than ace' would mean 'Faces' as in Stay With Me! Now That's What I Call Music!
  28. Goooner
    Jul 23, 2005
    19,434
    +2,410
    Think you got it Tone, it's a five pack from Now That's What I Call Music 597 or whatever we're up to now.
    God, I feel old, remember buying the first one when it came out :)
  29. Hugh
    Hugh Active Member
    Mar 31, 2003
    1,318
    +269
    If you have number 4 on CD, you could just get yourself another part of the Dream rig. Sells for £300+
  30. Christian 71
    Christian 71 Active Member
    Sep 3, 2011
    3,227
    +818
    Also stick to pickup position 2 in calibration and generally in Rocksmith. As you don't have an amp you may not have realised the benefits of position 2 and 4 for hum cancelling (dual pickups)
    Rocksmith has noise cancelling but it has to know how noisy the guitar is, touching the strings earths as bilbo says hence the above is worth a shot.
    You wanting to plug into an guitar amp or an av amp?
