Ripping DVD's to laptop
Discussion in 'Blu-rays, DVDs & Streaming Services' started by Tomo1971, Jun 15, 2008.
  1. Tomo1971
    Tomo1971 New Member
    Dec 30, 2004
    193
    +6
    I am not wanting to do this for illegal activities.
    Thought I would get that out of the way first as thats what sime ppl could assume!!
    Just bought myself a new laptop to carry round primarily while Im away from home working.
    Instead of taking shed loads of dvd's with me is there any software (free hopefully) that I can rip the DVD onto my hard drive with.
    In honesty, I have copied a couple of DVD's a few years back but found it too long winded and ended up making coasters of 9 out of 10 discs so gave it up as a bad job!! Thats not for me now, easier to get old DVD's from the bargain bin!
    All I am looking to do is copy DVD's that I own to my hard drive in a format so that I can view them not a format to be copied.
    Is there anything out there?
    Thanks, Steve
    Steve
  2. andyUK101
    andyUK101 Member
    Dec 30, 2006
    1,310
    63
    +128
    Plenty of software out there that will do this but all the simple and easy to use stuff will cost something
    If you dont mind paying for software then DVDFAB is very handy with lots of options which are easy to configure once you get the hang of it
    If you are absolutely set on free software then DVD Decrypter and AutoGK should be enough for what you want but are a little bit more complicated to use
    The forums at Doom9 have quite a few handy guides for exactly what you are looking to do, covering most of the available tools
    • Thanks Thanks x 1
  3. Tomo1971
    Tomo1971 New Member
    Dec 30, 2004
    193
    +6
    Thanks, that does give me somewhere to start. Just to re-iterate im wanting to do this with DVD's I already own and not for p2p use etc.
    steve
  4. winka45
    winka45 Member
    May 3, 2007
    615
    +21
    As I speak I have DVDFAB doing a rip to for my Archos, You get 30 days free, so Im going to see what its like. It's perfect for me because it actually has a PVP option.
    Messed around with DVDdecrypter all day yesterday, but it rips onto my laptop but then I cant watch it, there just all different files?? Im sure the first time I used (a year ago now) it it made one image that I just clicked on and the movie started.??
  5. Goooner
    Goooner Well-Known Member
    Jul 23, 2005
    20,086
    +2,744
    For my Archos, I tend to use DVD Decrypter to rip them, then FairUse Wizard 2 to convert them to Xvid or Divx.
    FairUse is free, and will encode anything to a file size of up to 700mb, if you want a bigger finished file, then you need the paid for version. As I found it so good and easy to use I bought it anyway, it was $20 or something, but I found the 700mb encodes, perfectly watchable on my Archos.
  6. andyUK101
    andyUK101 Member
    Dec 30, 2006
    1,310
    63
    +128
    I used AutoGK for a while, and before that the original GK software bundle with excellent result, as an added plus they are all free
  7. mikegambit
    mikegambit New Member
    Apr 2, 2008
    1,619
    +129
    Surely DVD Shrink is the easiest?
    Stick the disc in ,open Shrink which analyses then encodes it to the Hard Drive - end of job.
    If you do another disc with it just change the name of the folder it copies to when it asks to "BACKUP"?
  8. imjay
    imjay Member
    Jan 30, 2008
    175
    +24
    DVDShrink is simplist and, so far, I haven't found a dvd that it won't decrypt and compress to single layer disc size though some of the sites post of some current dvds that shrink can't process. The free version of "Fab" seems to work (used it once as a test) but as previously posted "shrink" easiest application to use.
    Interesting that it sounds like in the UK legal copying of dvds you have purchased is legal under "fair use" doctrine. In the US Supreme Court boneheads ruled that if content has some sort of copy blocking encryption is it illegal to make a "fair use" copy. Fortunately, the software couldn't care less!!!
    goodluck
  9. josheyb
    josheyb Member
    Nov 19, 2007
    19
    3
    The following link is a guide to how I rip DVDs to my pc. Most of it is based around allowing media centre to work with copied films, but the basics are just the same. Each film's around 5gb but DVD quality, so if space is an issue this might not be for you.
    You could follow this guide and only use DVD Decryptor and VLC player if you just want the basics. - Both free legal programs.
    http://www.aphavoc.co.uk/sidewy/dvd_ripping_guide.htm
    (Note I didn't write most of this, just collated it from different sources.)
    Hope that helps.
  10. Corey USA
    Corey USA Member
    Jun 13, 2007
    794
    +23
    Be warned This nolonger legal especially in the usa NOT EVEN UNDER FAIR USE!
    here is a couple of links. I will post more links as I find them.
    Doom9.net - The Definitive DVD Backup Resource
    Click on the DMCA Analysis in the top bar right under the bold "doom9. net"
    You are not violating copyright under fair use by putting it on your computer.
    What your violating is the DMCA Which is circumvention of copy protection
    Thus after a ruling just made in the USA Fair Use is dead fair use and circumvention go hand in hand. they can not be separated
    This also means watching DVD on a linux platform is illegal as well for it uses tech to circumvent.
    RealNetworks Loses First Round In DVD Software Lawsuit - DVD , Home Theater
    Real looses first round.
  11. confused88
    confused88 Member
    May 15, 2009
    1,246
    +70
    After the 30 days evaluation period you can still use the DVD fab decrypter. It creaters a folder separated in audio and video. If you click the VideoTS file from the Video folder option the movie will play. It's an 1:1 copy that keeps the dvd folder structure intact.
