Resetting a Panasonic SkyBox
Discussion in 'Sky Forum' started by mjn, Sep 8, 2004.
  1. mjn
    mjn Active Member
    May 24, 2001
    14,731
    +1,563
    I've got a Panasonic sky box, that hasn't been used in about 4 years! But the girlfriend has just moved house, and it has a sky dish already fitted and an outlet in the living room.
    Plugged my box in, but after searching for a signal it shuts down. I guess it could need an update or something. I vaguely remember a service code you could enter when the box was in standby that would reset the box, and check for updates.
    Anybody know what it is?
  2. Clint C
    Clint C Member
    Dec 10, 2002
    420
    +4
    I have a Panasonic DSB30, not sure what model you have but the same may apply. Unplug from mains, press and hold "Backup" button on receiver whilst plugging back into mains. Keep your finger on the backup button until you see a notification that the update's taking place which occurs after about 5 - 10 seconds.
    HTH
    Clint.
  3. mjn
    mjn Active Member
    May 24, 2001
    14,731
    +1,563
    thanks for that, i'll pass it on to the g/f and we'll see what happens
  4. mjn
    mjn Active Member
    May 24, 2001
    14,731
    +1,563
    just to let you know...the tip did the trick, new software downloaded, and the sky is working once again.
    thanks for that! :thumbsup: :smashin: :thumbsup: :smashin:
  5. Clint C
    Clint C Member
    Dec 10, 2002
    420
    +4
    Excellent, I'm glad it worked out.
    Clint.
