Reformatting Sky HD HDD
Discussion in 'Sky Forum' started by chadmaster, Feb 6, 2010.
  1. chadmaster
    chadmaster Member
    May 7, 2007
    7
    Hi.
    Can anyone tell me how to reformat my Thompsons hard disc drive from within the Sky Tech menu, I know how to get into the menu 0 0 1 select but I don't know where to go from there.
    My reasons for doing it is that I have had problems with my box blue screening and pixelation during play back. I have had the PSU checked out and it seems ok ie no bulging of the capacitors so have been advised to try this next.
  2. kevmarshall
    kevmarshall Member
    Apr 11, 2006
    1,607
    +221
    PC problem.......See edited post below.
  3. kevmarshall
    kevmarshall Member
    Apr 11, 2006
    1,607
    +221
    I sugest you try a Planner re-build first. This will retain your recordings........
    Services-0-0-1-Select-7
    If you mean you want a complete Re-set and lose all your recordings.......
    Services-0-0-1-Select-8
  4. kinmel
    kinmel Member
    Jul 1, 2006
    5
    3
    Do a factory reset.
    Take the mains power out of the box, or switch it off at the wall socket.
    Press and hold both left and right arrows on the top of the box and whilst keeping both pressed, plug back into mains.
    After a delay the record light will show, at which point you release the left and right and press the centre select.
    Re-boot the box once it's finished.
