Record One channel Watch another !!! TOSHIBA!
Discussion in 'Blu-ray & DVD Recorders' started by TOS, Sep 8, 2009.
  1. TOS
    TOS Member
    Sep 8, 2009
  2. grahamlthompson
    grahamlthompson Well-Known Member
    Aug 3, 2006
    18,738
    163
    +3,098
    With a single tuner device only channels in the same multiplex as the tuner is recording can be viewed and this only works on some recorders (some will let you record two from the same multiplex using only 1 tuner). To get a 100% second channel view or record requires a 2nd tuner
  3. Geofbob
    Geofbob Active Member
    Jun 15, 2005
    2,293
    83
    +312
    Are you quite sure it says that on the box? This recorder - like all those of this type - has only one digital tuner, so there is no way using this machine alone that you could record one Freeview channel, and watch another. The only way that you could do that with this recorder is by using it in conjunction with either a Freeview TV or a Freeview box. However, for the time being what you should be able to do - if you still get analogue in your area - is record Freeview and watch an analogue channel on your TV.
    PS I now see from the detailed spec that it has both a digital tuner & an analogue tuner, so the box is correct, but only in relation to one digital channel & one analogue channel - not two digital channels.
  4. fernandez
    fernandez Active Member
    Jun 5, 2005
    6,028
    +1,039
    Perhaps this (?) from the extended specs is what it means
    DVD Recording – Event/month timer 36/1, Max recording time 284 hours, Simultaneous play and record
    VCR Recording – Event/month time 36/1, Simultaneous play and record
    But, unfortunately, it doesn't mention twin Freeview tuners or being able to watch one Freeview channel and record another at the same time:(
    Toshiba RDXV59DTKB Freeview+ 250GB Hard Drive Drive DVD: Amazon.co.uk: Electronics & Photo
  5. LV426
    LV426 Administrator
    Jul 14, 2000
    11,786
    +3,075
    I have merged two identical threads and a third has been deleted. Please post questions once only. Thanks.
  6. marty2005
    marty2005 Active Member
    Jul 22, 2005
    3,692
    +175
    It just means you can record a TV channel and watch a previous recording like all DVD Recorders.
