quickest way to transfer large files
Discussion in 'Computer Software & Operating Systems' started by JFRTDI, Jan 16, 2012.
  1. JFRTDI
    JFRTDI Well-Known Member
    Jun 19, 2010
    2,310
    63
    +120
    Any one know what would be the quickest way to transfer 100gb off my laptop to my htpc!
    Would usb to usb be sufficient or would a network patch cable be quicker or setting up a LAN?
  2. imightbewrong
    imightbewrong Active Member
    Dec 6, 2005
    21,668
    +3,878
    I would think 100GB would take under an hour with a USB2 conenction. Doubt you could beat that with a network cable by the time you've got it set up :)
    (based on 40MB/s transfer rate with USB)
  3. JFRTDI
    Jun 19, 2010
    2,310
    63
    +120
    under an hour? holy **** !!! Ive been waiting near 15 hours over night for it.... still not done !!!
  4. imightbewrong
    Dec 6, 2005
    21,668
    +3,878
    sounds broken :)
  5. JFRTDI
    Jun 19, 2010
    2,310
    63
    +120
    Getting 4.5 mbps :(
  6. JFRTDI
    Jun 19, 2010
    2,310
    63
    +120
    how do i set up usb 2 usb?
    plug in both an away u go?
  7. imightbewrong
    Dec 6, 2005
    21,668
    +3,878
    Yep - worth checking both ends are actually USB2 and are running as USB2.
    How many files are you copying? A few, or millions?
  8. JFRTDI
    Jun 19, 2010
    2,310
    63
    +120
    some how, its done it now :\
    i went to scan to buy a cable, come back and it said complete, checked all files and they are all there :|
    ODD !!!!
    Was copying 70GB, got another 40GB to do later though
  9. themediaman
    themediaman Member
    Nov 17, 2010
    1,914
    +169
    teracopy seems to add a few MB...............
  10. JFRTDI
    Jun 19, 2010
    2,310
    63
    +120
    teracopy?
  11. themediaman
    themediaman Member
    Nov 17, 2010
    1,914
    +169
    TeraCopy is designed to copy and move files at the maximum possible speed. It skips bad files during the copying process, and then displays them at the end of the transfer so that you can see which ones need attention. TeraCopy can automatically check the copied files for errors by calculating their CRC checksum values. It also provides a lot more information about the files being copied than its Windows counterpart. TeraCopy integrates with Windows Explorer's right-click menu and can be set as the default copy handler.
    Taken from website, Google it...........
  12. Reddish
    Reddish Member
    May 12, 2011
    23
    When i live stream from venues and the internet router box is 20ft plus away, I use a 100ft Cat6 line. Sometimes I use the Cat6 line when im standing right next to the router. I believe information travels much faster through a Cat6 then through the wireless or in your case LAN.
    So with that info I am guessing that USB2 is your best option however if you did have a short Cat6 line that was short it could speed things up quick. sears have a 7ft one for $11 I think.
