Quick one: F-plug
Discussion in 'TVs' started by supersleuth, Apr 2, 2012.
  1. supersleuth
    supersleuth Member
    Mar 9, 2011
    233
    +4
    Quick one.
    Can I strip off the connectors of a standard TV aerial coaxial cable and attach f-plugs? Or do f-plugs require a different type of cable?
    I'm thinking of doing this for splitting multiple TVs from a single aerial source and f-plug splitters seem to be better
  2. Trollslayer
    Trollslayer Active Member
    Feb 11, 2007
    9,408
    +1,428
    No. You can buy adapters to do this, much easier
    • Thanks Thanks x 1
  3. logiciel
    logiciel Moderator
    Feb 2, 2008
    45,575
    +4,418
    Adapters would be easier, but yes you can and it's the other way round - different cables need different f-plugs.
    I don't see why f-connections would be any better for splitting though.:confused:
    • Thanks Thanks x 1
  4. stewwy
    stewwy Member
    Sep 13, 2004
    26
    3
    F-plugs and 'aerial' plugs are for cables with different impedances, for long runs of cable I would suggest using the correct cable to avoid a poor signal. it probably will not matter too much for a short length. However an ariel cable carries virtually no voltage but a Sat cable (f-plug) carries a voltage to power the Dish LNB,
    edit : Sat cables are in addition usually of higher quality
