PSU for speakers making weird noise
Discussion in 'Computer Peripherals & Consumables' started by waggy44, Mar 2, 2012.
  1. waggy44
    waggy44 Member
    Dec 30, 2008
    45
    The PSU for my Corsair SP2200 speakers is making a weird kind of screeching noise all of a sudden. I have no idea what's causing it as they were working fine just yesterday. The actual speakers work perfectly fine, it's just the PSU that's screeching and it's a little concerning.
    Does anyone know what could be causing this and how to stop it?
    Many Thanks
    Chris
  2. namuk
    namuk Well-Known Member
    Oct 23, 2006
    21,545
    +3,978
    sounds like capacitor whine or coil win, can you post a vid of it to confirm if it is then it is a new psu.
    Edit: sound like this?
  3. waggy44
    waggy44 Member
    Dec 30, 2008
    45
    Not quite as severe. I'll get a video made and upload now.
    EDIT:
  4. namuk
    Oct 23, 2006
    21,545
    +3,978
    post your system spec as well and any changes done since the noise :)
  5. waggy44
    waggy44 Member
    Dec 30, 2008
    45
    My Specs are:
    Windows 7
    Gigabyte GA-770TA-UD3
    AMD Phenom II 995
    Geil Value 4gb DDR3
    ATI Radeon HD 5850
    OCZ ModXStream Pro 500w
    The speakers are Corsair SP2200 as stated above.
    I've just installed a fresh copy of windows 7 on my system and the only changes have been the windows updates.
  6. namuk
    Oct 23, 2006
    21,545
    +3,978
    is the noise defiantly coming from that pack? bet there not cheap if that's a custom kit for the system.
  7. waggy44
    waggy44 Member
    Dec 30, 2008
    45
    ye, it took me a little while to locate the source of the noise but it's definitely coming from the speakers power pack. I just can't understand what would make it create that noise. Guess it's a case of buying a replacement. Annoying.
  8. namuk
    Oct 23, 2006
    21,545
    +3,978
    when did you get the setup? as it has a 2 year warranty Corsair Gaming Audio Series
    dealing with corsair direct will be better and faster if your still under warranty if just out post up on there forum as you never no, there support is second to none mate :).
  9. waggy44
    waggy44 Member
    Dec 30, 2008
    45
    ah ok cheers. they were an xmas gift. tranna track down order details now.
