PS3 Technical support number
Discussion in 'PS3 Forum' started by puma2020, Mar 24, 2007.
  1. puma2020
    puma2020 Guest
    Hi all,
    Does anyone here know how I can contact Sony technical support by phone.
    I can't add card details in the account info and it says to contact technical support.
    Many thanks,
    Duncan
  2. samjpullen
    samjpullen Active Member
    Nov 24, 2004
    3,762
    +151
    Will it not be in your Manual.....
  3. singhie
    singhie Guest
  4. bulletmagnet
    bulletmagnet Member
    Nov 30, 2005
    2,244
    +159
    i know this number well already !!
    08705998877
  5. puma2020
    puma2020 Guest
    Thanks everyone,
    I got the number but they are not there now that I've finished work.
    Will try tomorrow.
    Thanks again,
    Duncan
  6. Callum_LC
    Callum_LC Guest
    Have you solved this issue yet 'cos I have the same issue I think, how do you solve it or is it best I ring up Sony?
  7. cols
    cols Active Member
    Sep 5, 2008
    3,338
    +529
    Try the thread "site maintenance - cannot add funds" in the ps3 playstation network > ps3 playstation network store forum - i had the same problem and the solution in there sorted it for me. :smashin:
