PS3 box dimensions
Discussion in 'PS3 Forum' started by Sunshinewelly, Feb 28, 2007.
  1. Sunshinewelly
    Sunshinewelly Active Member
    Dec 1, 2005
    3,881
    83
    +245
    as per the post - could some kind soul measure their import Ps3 box and post a measurement.
    I am off to HK and want to know whether i will fit the box as well in my hand luggage.
  2. Tigerblade
    Tigerblade Active Member
    Apr 6, 2004
    7,925
    +602
    Roughly, give or take a few mm :D
    12.5"/32.5cm High
    11"/28cm Wide
    4"/10cm Deep
    :smashin:
  3. Tejstar
    Tejstar Active Member
    Dec 4, 2002
    22,290
    +1,012
    Any idea of the weight of the box too?
    EDIT: Including the PS3 of course! :D
  4. Kieron
    Kieron Moderator
    Aug 25, 2004
    11,188
    +2,830
    *Very* heavy.
    It's too big with the box to go in hand luggage.
    All the innards are cardboard though, so you can flat pack it in your suitcase with the controller and leads. Then wrap the PS3 in a towel and pop it into your hand luggage. Keep your hands on it at all time! Put it under the seat in front of you.
    Exactly the way that I did it when I brought it home from Florida last year.
  5. Tejstar
    Dec 4, 2002
    22,290
    +1,012
    Heavier than 5kg?
  6. Tigerblade
    Apr 6, 2004
    7,925
    +602
    Just weighed the console on its own and it is 5.1kg :eek:
    The cables and controller won't add much.
  7. Tejstar
    Dec 4, 2002
    22,290
    +1,012
    I see. :eek:
  8. Sunshinewelly
    Dec 1, 2005
    3,881
    83
    +245
    i need the measurement of the box not the console itself
  9. Killie81
    Killie81 Member
    Apr 8, 2006
    306
    +12
    In regards to bringing the console through as hand luggage, do you need to take it out the bag when you put it through the x-ray machines?
    I noticed when I flew to Birmingham recently that they said all large electronics like laptops needed ot be put through out of the bags.
    Thats going to be a pain as i have to do some connecting flights which means probably going back through security again.
  10. Tigerblade
    Apr 6, 2004
    7,925
    +602
    I'll dig it out tomorrow and measure it but it's a big beasty.......
  11. oaklandraiders
    oaklandraiders Member
    Aug 2, 2002
    943
    +5
    Yo
    Sadly I eagerly await the box size as well !
    John
  12. Kieron
    Kieron Moderator
    Aug 25, 2004
    11,188
    +2,830
    I didn't. It was scanned at Florida going out - guard opened the bag and took a quick look, said fine.
    No checks at Manchester whatsoever.
  13. Tigerblade
    Apr 6, 2004
    7,925
    +602
    Apologies for taking so long with these, been a bit busy.
    Anyway here are the box dimensions :
    Width : 17"
    Length : 13.5"
    Depth : 7"
  14. Tejstar
    Dec 4, 2002
    22,290
    +1,012
    Thanks Tigerblade - the box is bigger than I thought.
  15. oaklandraiders
    Aug 2, 2002
    943
    +5
    Yo
    Just to check that inside of box is cardboard only, no foam or polystyrene ?
    John
