PS2 RCA connection
Discussion in 'PS2 Forum' started by alex12345, Feb 29, 2008.
  1. alex12345
    alex12345 Member
    Feb 29, 2008
    3
    Hi, I just bought a sun visor screen for my car and these are the two video inputs:
    [​IMG]
    Any idea how to connect an RCA cable from my playstation 2 to these? Can i get an adapter?
    cheers
  2. fallenangle
    fallenangle Member
    Oct 19, 2005
    404
    +24
    Those are weird connections for a screen to have. You would have thought whatever they were they'd both be female (ie. sockets).
    The yellow lead is probably the video connection corresponding to the yellow lead on a normal PS2 composite cable (yellow: video, red, white for audio R/L)). But what that single white RCA socket is doing I'm not sure. Does the screen have built in amp/speakers? If so it's probably a combined audio connection.
    What you'll probably need is a RCA male to female (socket) converter for the video lead ie. just a simple RCA/phono coupler. If the white lead is for audio you'll need a RCA/phono doubler which converts the R/L audio red/white PS2 composite leads into a single male RCA plug.
    Both of these are readily available for electronic stores for a few £/$.
    But I'm not confident about this advice as regards the audio so please don't take it in isolation. I'd be looking at the screens instruction manual/specs just find out exactly how the leads are decribed.
