Problems with Handbrake and Disney
Discussion in 'Apple TV' started by MIB, Oct 10, 2011.
  1. MIB
    MIB Member
    Apr 29, 2005
    1,896
    +95
    Using handbrake to rip and encode dvd's to apple tv and mainly works great but some of the kids films, mainly Disney play in a jumbled up order. Anyone else had this problem and managed to find an easy workaround?
  2. next010
    next010 Active Member
    May 29, 2005
    9,305
    +1,801
    Have you tried putting them in a video playlist in iTunes so they are in the right order.
  3. MIB
    MIB Member
    Apr 29, 2005
    1,896
    +95
    Not sure I made myself clear, sorry. I mean when watching a particular film, like astro boy, the chapters are all jumbled up and you might see the ending part half way through.:confused:
  4. next010
    May 29, 2005
    9,305
    +1,801
    I see well it sounds like Handbrake took the wrong video track from the disc, taking one which is intended for interactive features or director commentary.
    I always prefer to rip to the HDD first using MakeMKV (Win/OSX) and this will extract the main movie as a standalone video with no conversion, then a quick check in VLC to make sure it's all correct and feed the MKV file to Handbrake for processing.
    You could also try previewing the video stream in Handbrake directly if VLC is present, cycle through the title section to find the right one when importing video_ts
    • Thanks Thanks x 1
  5. MIB
    MIB Member
    Apr 29, 2005
    1,896
    +95
    Thanks, I'll try finding which tracks actually play the movie from now on and might try ripping first then jsut encoding with Handbrake. Had major problems with Thor last night but after some googling looks like I'm not the only one. Had to download LongoMacRipper in the end which worked a treat.
  6. CamFire
    CamFire Active Member
    Apr 26, 2009
    3,994
    +520
    Had this same problem a while back. Use RipIt for the ripping and Handbrake for the compression.
