Problem with XBOX live
Discussion in 'Xbox Live Forum' started by per12389, Jun 25, 2009.
  1. per12389
    per12389 Member
    Apr 18, 2009
    4
    Hello,
    I am having a problem with private chat on XBOX live. It used to all be fine but the other day it says my NAT type is strict. I have already opened the necessary ports prior to this and it told me to reset my router. After doing this, everything looked fine but when I pressed Y to see status report, it said: Error status report
    W: 0000 - 0021
    X: 0000 - F001
    Y: 20A8 - 48E0
    Z: 0000 - 0000
    It's weird because I can still play online on street fighter 4, but cannot join my friends private match nor chat. I have googled around but cannot find the exact problem. Any help would be much appreciated.
  2. markgodley
    markgodley Active Member
    May 25, 2008
    3,738
    +642
    Is it showing your status as strict still? Im pretty sure if u reset your router it would reset it to default i.e removing all the ports you just opened.
  3. per12389
    per12389 Member
    Apr 18, 2009
    4
    No it doesn't reset the settings, just reboots the router. Do you suggest going to factory settings and starting from square 1? The NAT type no longer says strict. It is a Belkin N Wireless router (F5D8233-4v3) if that helps.
  4. markgodley
    May 25, 2008
    3,738
    +642
    When you said you was doing a reset it i assumed u was doing a hard reset (press the reset button on modem)
  5. markgodley
    May 25, 2008
    3,738
    +642
    Is your router pretty old. I'd suggest to see if you can update the firmware on it?
  6. Rick Shaw
    Rick Shaw Member
    Nov 21, 2008
    197
    43
    +110
