Problem with Tomtom one
Discussion in 'ICE, Sat Nav & Dash Cam Forum' started by MDUK, Feb 11, 2006.
  1. MDUK
    MDUK Member
    Feb 10, 2006
    37
    is this thing meant to work straight from the box?
    i have just turned it on and it is flasing an SD card with a big red cross through it, even though the sd card has been inserted.
    anyone able to tell me please.
  2. Crocodile
    Crocodile Well-Known Member
    Nov 4, 2002
    12,790
    +2,732
    It would suggest that it's not reading the SD card. Remove the card, reset the the unit & re-insert the card. If still no joy try the card in a card reader (if you have access to one) to see if you can read it there.
  3. IanS
    IanS Member
    Aug 10, 2005
    939
    28
    +68
    make sure that the SD card is not write-protected as well.
  4. bibamus
    bibamus Member
    Dec 10, 2005
    972
    +43
    Surely it wouldnt matter if it was write protected, doesnt the unit just read off the sd card?
    allan
  5. IanS
    IanS Member
    Aug 10, 2005
    939
    28
    +68
    I thought that it created some work files on the card? Plus it updates things like last destination .....
  6. BCH
    BCH Guest
    Same here i just put a updated card in with cameras and sounds no joy..:confused:
  7. AFSTER
    AFSTER Member
    Sep 28, 2005
    1,335
    48
    +27
    I got one at the weekend from PC World and opened in the car and put the card in and everything working fine, used it that day
  8. KeithO
    KeithO Member
    May 28, 2003
    1,436
    63
    +217
    It makes no difference...TomTom ignores the write-protect setting, and can write to the card whether it's set or not.
  9. Mackh
    Mackh Guest
    You almost certainly have a faulty SD card.
    I had an identical problem with a TomTom One I bought from PC World a couple of days ago. I spoke to the TomTom support desk who suggested there was a problem with the SD card. They suggested I try to download the latest version of the software, but my computer wouldn't even recognise a card was present.
    Took it back for a replacement and got the replacement up and running in lesss than 5 mins in PC World's car park.
  10. sickofusernames
    sickofusernames Member
    Jan 22, 2006
    171
    Yep, I had same problem when I bought mine from Comet. 5 mins after buying I took it straight back to the Repair Desk and they got me a new one which is working fine.
  11. tomlou
    tomlou Guest
    After using the TomTom One XL for a trip 2 weeks ago, and having it work as it is supposed to, I turned it on today and it makes the TomTom sound, shows the Splash screen and then shuts off. It does this on battery and while on the charger. Resetting it has made no change.
    I've hooked it up to the computer and to TomTom Home, did a restore, etc, etc and nothing happens. The TomTom help desk is closed for the day, but I want to find out what can be done TONIGHT. The PDF manual that came with my unit has nothing to help me.
    I held the on/off button in for several seconds longer as it was starting, and got a black/white text screen with info on the unit, dates updated, etc, etc and under "startup mode" it says "sleep." I tried typing "sleep" and all that into the search function in Adobe Acrobat to search the manual and got nothing.
    What do I do, short of waiting for TomTom to open up for customer support tomorrow?
  12. Supernaught
    Supernaught Member
    Jan 3, 2007
    253
    28
    +35
    I had a similar experience with my Tomtom One.
    It didnt come with a memory card at all, everything was on the units own memory.
    I updated and tried to add the speed camera database and was told the memory was full, so I inserted a blank SD card and copied the speed camera stuff to that.
    When I disconnected the Tomtom from the computer and switched it on, I got the same error screen as the original poster.
    From a lot of playing around I have come to this conclusion:
    The tomtom will take its information from the built in memory, or the SD card, but not both at the same time.
    I copied absolutely everything from the Tomtom to the SD card and switched it back on with the card in and it worked fine.
    Whether this is a problem with the unit or intentional I dont know. I may even be totally wrong in my conclusion, but after a lot of playing around thats what I came up with.
  13. Super Milo
    Super Milo Guest
    I turned my Tom Tom One on yesterday and heard the 'Tom Tom' jingle then the screen came up with the picture of the bus lane etc, but nothing else happens. It is locked on that screen and wont budge. Anyone got any ideas what I can do to get it going again? Cheers.
  14. Supernaught
    Supernaught Member
    Jan 3, 2007
    253
    28
    +35
    Get a pin or a toothpick or similar, and poke it into the "reset" hole near the usb port on the bottom. Should work fine after that.
    If not, plug it into your PC and get Tomtom Home to run it. That should give it a kick up the arse.
    Hope that helps.
  15. SOTHC
    SOTHC Member
    Feb 16, 2008
    2
    According to Halfords there is a problem with the Tomtom website and they have had a lot of returns from people who have downloaded from the site. I have had to get a replacement unit as yesterday, I downloaded the latest upgrade and it cooked the simcard. I then only got the error sign and couldn't reset it or connect back to the computer. Halfords have recommended that I do not connect the replacement to the Tomtom website before April
  16. kevinx
    kevinx Member
    Nov 20, 2007
    7
    3
    They didn't mention April 1st, did they??
