Playing bdmv files
Discussion in 'Streamers & Network Media Players' started by paultr, Nov 24, 2007.
  1. paultr
    paultr Member
    Aug 6, 2003
    52
    9
    I have come across a file of a blu-ray movie. It is in a format which is new to me. I think it is some kind of image of the blu-ray disc. There are lots of folders such as Audio_TS, Meta, Playlist & Stream. The Stream folder contains *.mt2s files.
    I have in the past been able to stream *.ts files to my Snazio. Is there any way to convert these blu-ray files so they would play?
    TIA
  2. Azzin
    Azzin Well-Known Member
    Nov 5, 2005
    23,860
    +3,078
    You "came across" the files-don't you mean you downloaded them from usenet? :smashin:
    Anyway, the only program that can play these via a PC is PowerDVD Ultra.
    • Thanks Thanks x 1
