Pioneer VSX921 owners thread
Discussion in 'Integrated Amplifiers & Receivers' started by ZXSpeccy, Aug 12, 2011.
  1. JohnSteam
    JohnSteam Member
    Feb 13, 2012
    2
    Thank you, Morgan71 and matman.
    AirPlay opens up lot of possibilities, that's true. But native support still would be a nice plus since no iDevice is needed...
    JS
  2. Log1k
    Log1k Member
    Jan 15, 2012
    3
    Quick question. Which is better to use. I am streaming stuff from my PC via 1.4a HDMI ti the amp and then pass through the picture to the tv. On the properties of the HDMI on PC you can choose ho you want the sound to come out eg. stereo, 5.1 (my setup on the amp), 7.1 etc.
    If i use stereo setting, i can decode the source on the amp to 5.1 by using dolby digital or Neo 6 matrix but
    if i use 5.1 the amp forces the PCM state on and i can just select auto ( so as is) or stereo.
    I think the latter gives the better sound quality, but it disables almost all the other enhancements too. So what do you suggest?
    - L
  3. Marc
    Marc Active Member
    Jul 8, 2004
    11,611
    +1,094
    if you're setting your pc to stereo then everything you send to your amp is being sent in two channels which the amp can then upmix using one of its pseudo surround modes, but you won't be hearing the discrete mix as encoded in the video. You're best off setting your pc to the correct number of speakers and then sending that to the receiver.
    i currently have my video player (daum potplayer) sending dd, dts, dts-hd, truehd via bitstream to the receiver and re-encoding pcm stereo signals into prologic and sending those to the amp as bitstream as well
  4. killabeez
    killabeez Member
    Jun 29, 2004
    Hi ,
    Just a quick ask ?
    Does anybody else have >volume< issues with this amp ?
    Upgraded from a Pioneer 814 to the 921 and the volume of the new Amp seams far lower than my previous Amp ?
    Tried the Macc setup a good few times but not much improvment :( all my channels are now turned up, well into the +'s
    Generally I have to have the Amp at -20db to -14db to listen to normal TV,
    Doesn't seam right to me ?
  5. Jonny3979
    Jonny3979 Member
    Jan 9, 2012
    I also find this amp much quieter than my old arcam avr100. I'm running much bigger better speakers too.
  6. killabeez
    killabeez Member
    Jun 29, 2004
    Thanks Jonny,
    Was starting to think my Amp was faulty :(
    Just can not believe that 150 watts into 6 ohm speakers can be that quiet :thumbsdow
  7. Morgan71
    Morgan71 Member
    Nov 30, 2011
    22
    3
    Power specs of 814 and 921 are more or less the same.
    Level from optical output of a TV could be lower than line level output.
    It happens on my PDP-LX5090H.
  8. killabeez
    killabeez Member
    Jun 29, 2004
    Tried the audio using HDMI through the ARC and the volume was about the same as the optical
    Tivo to Amp to TV, then back through the HDMI ( ARC ) to the Amp, no improvment :(
    When I play an Mp3 using a USB memory stick the volume does seam higher ?
  9. Woody26
    Woody26 Member
    Feb 12, 2007
    711
    +15
    Just got this amp. Have sky via hdmi in input one and the optical into optical 2. It's setup in the menu and has put the hdmi and optical together so I have picture and sound. Problem is, it doesn't give dolby digital output! The sky box is set to output this, what could it be?
  10. Woody26
    Woody26 Member
    Feb 12, 2007
    711
    +15
    I've worked it out, it's still taking the sound from hdmi and not optical, how do you change this?
  11. Jonny3979
    Jonny3979 Member
    Jan 9, 2012
    I have my sky hd box hdmi going directly to my tv then the optical going to the amp!
    Works fine except for the normal lip sync issues which the hd box seems to suffer from.
  12. Speedluvver
    Speedluvver Member
    Jan 31, 2005
    95
    You have to change the signal select from auto to manual so it always uses optical...
  13. matman
    matman Member
    Jan 3, 2007
    44
    When watching sky I usually have mine set at -30 to -40db. What speakers do you have?
  14. killabeez
    killabeez Member
    Jun 29, 2004
    Orginally MS302/MS304 fronts and MS904 at the back but just replaced with Dali Zensor1 and Vokal at the front, ( MS904 ) still at the rear, the sound level was the same for both speaker set up's though :(
  15. bobbybuilder
    bobbybuilder Member
    Feb 18, 2012
    23
    3
    Are there any good apps for Android for streaming music to 921, have tried Bubble upnp but get sound drops can't seem to get double twist to work, any ideas?
  16. empedocles
    empedocles New Member
    Feb 22, 2012
    Yes, same problem - amp currently being repaired: just wondered if you got any feedback from the store?
  17. maturestudent
    maturestudent Member
    Feb 22, 2012
    23
    3
    Hi everyone,
    just joined the forums, i set up my amp today and like jonny and killa have noticed that theres no loudness/kick. i have pioneer speakers, the cheap shs100 set but when i had them hooked up to an Onkyo they were loud so i feel its not the speakers but the amp. i can't believe that i have to go from -80db to -14db to get some decent sound out of it, this was not the case with the onkyo and still isn't as its set up in the other room. is there something i could not have set up correctly?
    btw i adjusted the speaker volumes manually to +6db each and that improved things, i get decent sound at about -40db which is a little better
  18. Marc
    Marc Active Member
    Jul 8, 2004
    11,611
    +1,094
    i've calibrated mine with mcacc twice since i've moved house. The first time, i had to put the receiver at -20 or so for a decent volume level, but the second time -35 is just as loud. Perhaps try doing mcacc again and see if it is any different.
  19. killabeez
    killabeez Member
    Jun 29, 2004
    Watched a move last night and had it up to -9db or so, just about had enough and will be returning this to Sevenoaks unless there is a solution soon :( well miffed off.....
    ps, got a 'silver' 814 in the attic that kicked the pants off this amp !!
  20. DaiGriff
    DaiGriff Member
    Dec 11, 2011
    11
    Have you tried changing the channel levels as per Mature Students suggestion?
    What level are your channels at?
  21. killabeez
    killabeez Member
    Jun 29, 2004
    Hi, ta for the advice, upped the channel levels to about the +5 to 7's its a little better but is this the right way to go ? still have the master volume up to the _10's or so :(
    Ps , am I going deaf ? :eek:
  22. bobbybuilder
    bobbybuilder Member
    Feb 18, 2012
    23
    3
    Hi do you mean pioneer 814? Because if so I to have just upgraded from that model also. Sorry to hear your having problems but all I can say I couldn't be more happy with the sound, volume levels are much higher than old model. Music via direct is wonderful put new life in my speakers. You must have a bad one so would return pronto.
  23. killabeez
    killabeez Member
    Jun 29, 2004
    Yep I did mean Pioneer 814, was a great amp, just the colour was silver and no HMDI inputs, so it had to go :(
    Does anybody know if when you set up the amp with the Mcacc setup the volume is 'set' by the amp, so possibly restricting the max volume ?
  24. Marc
    Marc Active Member
    Jul 8, 2004
    11,611
    +1,094
    i think the mcacc definitely sets the overall volume, as shown by me running it twice, a week apart and having much different results in that department but i don't know what affects it. The first time i ran the setup i did turn the volume down from 0 to -10 because the buzz of my speakers at 0 was causing the setup to say "too much ambient noise" but it turned out that was due to putting the mic on a cushion instead of something solid anyway.
    • Thanks Thanks x 1
  25. potshot
    potshot Member
    Jan 31, 2004
    1,855
    63
    +121
    I am setting this amp up for a mate and can honestly say the manual is the worst I have ever come across, a lack of detail and the most basic smallest manual I have come across.
    I am in the process of bi-amping the front speakers and its not the best diagram I have come across. We have had problems where the amp won't respond to the remote and we have needed to turn the amp off and on at the mains to get it work properly. Speaker volume is quite low but I am hoping when I have set the speakers to bi-amp the volume will improve.
  26. Marc
    Marc Active Member
    Jul 8, 2004
    11,611
    +1,094
    the printed manual is just a quick start but there's a pretty detailed manual on the cd/website. I occasionally have an issue where i can't get the amp to turn on, if i've turned my tv on first (some sort of dumb hdmi-cec issue), but that is fixed by turning the tv back off then turning on the amp.
  27. DaiGriff
    DaiGriff Member
    Dec 11, 2011
    11
    I get this problem too. Irritating!
  28. potshot
    potshot Member
    Jan 31, 2004
    1,855
    63
    +121
    You would think they would fix the problem via a firmware update. Thanks I will look on line for the manual.
  29. Marc
    Marc Active Member
    Jul 8, 2004
    11,611
    +1,094
    they haven't released any firmware updates in the few months i've owned it, was hoping it'd be one of those regularly updated things, adding features and fixes every month or so..
    my biggest annoyance with this receiver, which may or may not be fixable with a firmware update is the advertised "6 hd inputs" is sort of a lie. Yes there are 6 inputs, but you can only use 4 of them at any one time :( If you have something plugged into the DVD or BDR/DVR HDMI inputs, you lose access to the component inputs with the same names, and you can't reassign them to anything other than another HDMI input. I've actually had to resort to plugging the V+ box and Wii into my TV and using the ARC to the receiver instead of plugging them into the receiver as there's no space for them :(
  30. Tiggerbear
    Tiggerbear Member
    Mar 3, 2012
    Can anyone help, I bought the amp a few weeks ago still can't decide on a sub. I've been looking at some on Ebay but then realised I don't know if I need passive or active? As I understand it I could use either, but they get wired differently, but is one better than the other?
    Thanks.
    :lease:
