Pioneer Dvr Lx70d - Code For Multi Region Play and HD DVD's
Discussion in 'Blu-ray & DVD Recorders' started by Martinjay, Jun 25, 2008.
  1. Martinjay
    Martinjay Member
    Jun 25, 2008
    3
    New to the forums - hopefully you'll bear with me.
    I'm having some problems play HD DVD's on the Pioneer. I'm going to apply the latest firmware (4.17), but I'd also like to have it be region free in playback.
    Can anyone help with easy step by step instructions on how to do this please?
    Comments/advice about HD DVD playback also most welcome
    Many thanks
    Martin
    UK based
  2. ramjet
    ramjet New Member
    May 21, 2006
    3,760
    +676
    just done a google search for you on this recorder , and according to the results it does not play either type of HD disks , so I think you are wasting your time trying to use any HD disks in this recorder
    here are some details from a google search
    The LX70D is more than a premium hard disk DVD recorder, its an advanced media center
    that enables you to play, record and store almost every kind of media format. Now, you can integrate
    your digital lifestyle, including your digital photos and music collection, directly into your living room, most importantly,
    the LX70D enables a scaling option up to 1080p via HDMI. So youre guaranteed the highest viewing resolution,
    regardless of the source.
    Features
    * Digital & Analogue TV Tuner
    * 500GB Hard Disk Drive Capacity
    * +/- 1422 Hours (MN1) Max. HDD Recording Time
    * 1080p Upscaling
    * USB
    * DV In
    * Digital Audio Output Via Coaxial
    * PC Connect Via USB
    * DVD-/+R/RW, DL DVD-/+R, DVD-RAM Playback & Recording
    * +/- 24 Hours Max. DVD Recording Time (DVD-R DL Video)
    * Digital Electronic Programme Guide (EPG) (Guide Plus+)
    * Digital Jukebox for all MP3 & WMA Tracks
    * JPEG Slideshow with Music
    * 12-bit/108MHz Video Digital/Analogue Converter
    * RGB Output via Euro-Scart
    * Conditional Access Card Slot for Pay-TV
    * Pause Live TV
    * Videoplus
    * Commercial Skip & Back
    at no point are HD disks of either type mentioned
    as for multi region , it appears it can be done but I suppose it may need a service remote or something similar like the sony does
    so what makes you think it does HD disks ?
  3. Martinjay
    Martinjay Member
    Jun 25, 2008
    3
    Hi Ramjet,
    Thanks for the info. Of course, you're quite correct, I had simply assumed that for this kind of money replay of HD DVD's would be a forgone conclusion. Silly? Moi?! :mad:
    Martin
  4. ramjet
    ramjet New Member
    May 21, 2006
    3,760
    +676
    if you had wanted to play HD dvd,s then you could look for a toshiba or similar player , but as that format is discontinued leaving blu-ray then you may need a blue ray player or use a ps3 instead
    I think you may be getting mixed up with the Blueray Dvd Player they market here
    _http://www.dabs.com/productview.aspx?quicklinx=52DT
    known as the Pioneer BDP-LX70 Blu-ray PLayer , not dvr but bdp
    there are no recorders incorporating bluray in the uk as yet , so your recorder has no HD dvd playing abilities of either format
    I have the sony 970 myself , and the sony 1070 is similar to what you have bought in terms of hdd size ( 500 gig ) , and these x70 sony models are really rebadged pioneers and use the pioneer service remote or a one4all remote or a laptop or pda for making them region free , as discussed on the forums here in a massive thread
    so I would assume a similar fix is needed to make your recorder region free
    • Thanks Thanks x 1
  5. Martinjay
    Martinjay Member
    Jun 25, 2008
    3
    Hi Ramjet,
    OK checkout the site re: Sony multiregion fixes.
    Again, many thanks.
    Martin
