Picture of back of SKY HD box.
Discussion in 'Sky Forum' started by Paul D, Mar 25, 2006.
  1. Paul D
    Paul D Active Member
    Dec 27, 2000
    2,569
    +349
    Not sure if this has already been posted...
  2. Paul D
    Dec 27, 2000
    2,569
    +349
    Slightly different angle...
  3. Pebb
    Pebb Active Member
    Dec 29, 2005
    11,174
    +795
    Oh look an SATA connector, anyone know where you can get external SATA connectors from.
  4. Paul D
    Dec 27, 2000
    2,569
    +349
    Last one...
  5. blicky_1
    blicky_1 Member
    Jan 23, 2006
    2,280
    +177
    Ethernet connector looks interesting :)
    After someone has cracked how to unlock it that is!!
    • Thanks Thanks x 1
  6. choddo2006
    choddo2006 Active Member
    Dec 30, 2005
    8,526
    +610
    They're included in the box by the look of it
  7. ash
    ash Active Member
    Jun 9, 2005
    11,024
    +430
  8. Pebb
    Pebb Active Member
    Dec 29, 2005
    11,174
    +795
    Thats would be good, if they do I bet one end would be the SATA connector. Then the other part of the cable would be split into firewire and USB2 connector.
  9. Paul D
    Dec 27, 2000
    2,569
    +349
    The ports are...from the left to right:-
    Antenna input 2 (From LNB)
    Antenna input 1 (From LNB)
    Telephone line
    Serial port
    Aerial input
    RF output 1
    RF output 2
    S/PDIF optical out
    USB
    Component out
    Phono out left/right(stereo)
    SVideo out
    VCR scart(top)
    TV scart (bottom)
    HDMI
    Ethernet
    SATA
    240v Power input
    • Thanks Thanks x 1
  10. pr1970
    pr1970 Member
    Jul 12, 2005
    180
    +3
    I would prefer to see a real picture rather than a computer mock-up though. Anyone got one?
  11. Chevalier
    Chevalier Member
    Mar 17, 2006
    79
    11
    +5
  12. Paul D
    Dec 27, 2000
    2,569
    +349
    I'm not sure what you mean?
    These pictures are direct from SKY, so should be exactly what our boxes will be like.
    Do you feel the shipping boxes will differ?
  13. Yant0
    Yant0 Member
    Sep 13, 2006
    75
    11
    +5
    Just got my F71-46
    Sky HD comming Sat.
    Just got 2 questions I dont think has been asked, May be wrong thread but will try :-
    Is the HDMI lead that comes with the HD Box any good or is it worth spending a little money on a better one?
    Also:
    Does any one know how to unlock the 160Gig HDD in the Thomson Sky HD box?
    Was told theres 2 inside but need codes to unblock the other hdd. :suicide:
  14. kalel795
    kalel795 Member
    Dec 9, 2006
    341
    +39
    you only get to use 160 of the HDD as sky use the other 140 for updates etc...
    and as for cables unless the one in the box is broke they are all the same
  15. Phil57
    Phil57 Active Member
    Jan 31, 2005
    3,697
    +522
    The HDMI cable is perfectly adequate, do not waste money on `all singing, all dancing` cables.................believe me they don`t sing and the don`t dance!
