Pics and info on Samsung UE40ES6800
Discussion in 'LCD & LED LCD TVs' started by cmawson1287, Apr 19, 2012.
  1. Cypermethrin
    Cypermethrin Member
    Jul 15, 2011
    32
    You are right bbci player is not yet available on any es model
    However as i understand it it will be released soon
  2. nikunj_cal
    nikunj_cal Member
    Aug 7, 2007
    80
    Any professional reviews out yet for the model ?
  3. Mr Fujisawa
    Mr Fujisawa Member
    Dec 29, 2004
    330
    +22
    So do we know if it's the same panel used in both the 6710 and 6800? Anyone know the input lag on these sets?
  4. nikunj_cal
    nikunj_cal Member
    Aug 7, 2007
    80
    Picking up my 40inch set next week !
  5. Swanneh
    Swanneh Member
    May 11, 2012
    2
    I've just installed my UE55ES6800. A couple of questions, can anyone let me know the best picture settings (i.e. the level to set brightness, etc. etc.) and also does this model have the ability to light up the samsung logo in the bottom centre of the frame? i've seen pictures where this appears to be the case, but cannot find the option in the menus.
  6. nikunj_cal
    nikunj_cal Member
    Aug 7, 2007
    80
    Quick question does the TV packaging has a handle or something so that I can carry it to the nearest busstop ?
  7. nikunj_cal
    nikunj_cal Member
    Aug 7, 2007
    80
    Anybody ?? I pick my set tomorrow !
  8. Cypermethrin
    Cypermethrin Member
    Jul 15, 2011
    32
    No handle i m afraid... You have to grasp it as best you can approx 15 kg
  9. nikunj_cal
    nikunj_cal Member
    Aug 7, 2007
    80
    Thanks , i have asked them to do a home delivery so that would mean 3 extra days . Should get it by this Friday !
  10. nikunj_cal
    nikunj_cal Member
    Aug 7, 2007
    80
    Hello
    Got my unit . Initial feedback is that the tv is great but I am facing some problem with clouding. Will loosening the backpanel and wiping the screen with a cloth (centre to the edges) help ?
  11. whitehart
    whitehart Member
    Oct 16, 2006
    1,371
    +86
    put some pics up, as some clouding will clear after around 100hrs of viewing
    it just depends on how bad it is
    • Thanks Thanks x 1
  12. nikunj_cal
    nikunj_cal Member
    Aug 7, 2007
    80
    Ok I will take some snaps and post the same
  13. whitehart
    whitehart Member
    Oct 16, 2006
    1,371
    +86
    cool yeah, it shall be interesting, most of, actually all of my clouding has gone now it started to clear up at around 100hrs useage I think these TV's need running in time. I'll compare it to how bad mine was at first, All i have now is slight light bleed in rhs bottom corner which again appears to be improving over time
  14. nikunj_cal
    nikunj_cal Member
    Aug 7, 2007
    80
    Ok i am not being able to get a decent snap to show the level of bleed. Any pointers ?
    Also could you also please share your calibration settings ??
  15. whitehart
    whitehart Member
    Oct 16, 2006
    1,371
    +86
  16. nikunj_cal
    nikunj_cal Member
    Aug 7, 2007
    80
  17. whitehart
    whitehart Member
    Oct 16, 2006
    1,371
    +86
    from what I've read these should be fine on your ES6800 as well as its a ES
  18. Cypermethrin
    Cypermethrin Member
    Jul 15, 2011
    32
    There is a new firmware out for the ue40es6800 checkut the samsung uk site
  19. Cypermethrin
    Cypermethrin Member
    Jul 15, 2011
    32
    • Thanks Thanks x 1
  20. nikunj_cal
    nikunj_cal Member
    Aug 7, 2007
    80
  21. nikunj_cal
    nikunj_cal Member
    Aug 7, 2007
    80
    Why is it that when I playback a movie using the all share feature the movie looks more like a tv series. However when i play the same using my wd tv gen1 it looks entirely different and like a proper movie ..
    I hope this made sense :)
  22. Cypermethrin
    Cypermethrin Member
    Jul 15, 2011
    32
    Well i updated too and now i cannot get the tv to connect to the wifi. It drops signals and basically goes from being connect to no picking unp the wifi to then picking up wifi and not connecting to the internet
    I have reset the router, the wireless router, the tv
    Still does it.
    What the hell are Samsung playing at this update has trashed the tv
  23. nikunj_cal
    nikunj_cal Member
    Aug 7, 2007
    80
    I just checked and my wifi is working fine. I also streamed some 1080p videos from youtube and they worked fine as well. I updated via usb how did u update ?
    • Thanks Thanks x 1
  24. Cypermethrin
    Cypermethrin Member
    Jul 15, 2011
    32
    Via USB...... Its also deleted all the apps from the top line of the hub screen (including netflix, history, 3d etc)
    Its very odd..... Somtimes it falls over continuously...... But just as i type this its all connected and stable
    Still not impressed mind
  25. nikunj_cal
    nikunj_cal Member
    Aug 7, 2007
    80
    Try switching channels of wifi...
  26. Cypermethrin
    Cypermethrin Member
    Jul 15, 2011
    32
    All other stuff works fine still ( ipad/laptop/ipod etc).....
  27. nikunj_cal
    nikunj_cal Member
    Aug 7, 2007
    80
    Any change log available anywhere for the update ?
  28. nikunj_cal
    nikunj_cal Member
    Aug 7, 2007
    80
    I agree with the samsung apps but I think the browser is terrific ! I played 1080p you tube videos from the browser and they all played wonderfully !! I suggest you plug in a wireless usb mouse and then try and surf. I currently use my mouse to surf and my android phone to type web address etc ! As per my needs it is good enough !
  29. tutts58x
    tutts58x Member
    May 19, 2010
    12
    Hi I no a couple of you on here already own the new ue40es6800 but my question is why have Samsung done away with the shinney screen finish on the new 6 range led,s .. It seem they have left off the Ultra Clear Panel .. Last years 6 series models all come with this screen .. I went to my local currys and looked at the es7000 and es6800 and noticed the screen straight away .. The es6800 screen has a matt effect .. It seem on the 8&7 series only have the ultra clear panel ?????
    Iv been on Samsung site and it confirms that 6 series hase no ultra clear panel how does this effect tv quality .
    I was going to get the 6800 but been put off buy the screen just wondering to the people who have got this model compaie to the ultra clear panel ... All previews models in the 6 series c & d all hade this panel why change .. I don't want to but the es7000 as I would not use the cam etc and paying a premium for it ... Thanks Chris
  30. aevans
    aevans Member
    Mar 20, 2006
    12
    I had this on my es6300 for a couple weeks. completely unusable. No problems with other devices on the network but i switched channels on the router and forced it to use 'G' only. since doing this everything has been fine
