Peugeot 307SW Blaupunkt CD Player- Help Req'd
Discussion in 'ICE, Sat Nav & Dash Cam Forum' started by smoggy4u, Nov 21, 2005.
  1. smoggy4u
    smoggy4u Guest
    Factory fitted Blaupunkt 5 Cd changer has just given up the ghost.
    Radio unit operating ok but CD will not select when SRC button pressed.
    All that is happening is that each CD slot (numbers 1 to 5) is flashing.
    Managed to get all but 2 CD's ejected.
    Unit seems to have "locked up" apart from the flashing indications.
    Any ideas would be gratefully accepted as kids are doing my head in!!
  2. conkerman
    conkerman Member
    Feb 21, 2005
    489
    28
    +42
    This is a very common fault. New unit req'd. they are pretty rubbish TBH
    Mine does it too. has ate some of my CD's too.
  3. Ruco
    Ruco Member
    Apr 3, 2010
    i have had two cars with this unit, both Peugot 307SW and both have had a problem. the first car had intermittent problems which i never could resolve, my most recent one stopped about three months ago. today i decided to do something about it. so i looked on the web and found this trail. i removed the CD changer and unplugged it from the cables then took it into the house and, on the basis that it was an intemittant fault assumed a good bashing might dislodge something, so gave it a good basking with the handle of a screw driver onall sides. i took it back to the car plugged it in and atleast this time it made a noise. i fed a CD in and nothing happened. i unpluged it a few more times, giving it extra bashes in between and then fed a CD in during power-up, hey presto it is working again.
    i guess something was stuck or mis-aligned or something and it is back in place now. of course i don't know how long tis will last bt it took be 20 mins so it is probably worthwhile trying.
    good luck
  4. martUK
    martUK Member
    May 22, 2007
    653
    28
    +73
    It is common that the mechanism breaks, they are made for Pug and the aftermarket version will not work so a new one needs to be sourced from a Pug dealer
