PCH A-110 - factory reset without display?
Discussion in 'Streamers & Network Media Players' started by thestorm, May 31, 2009.
  1. thestorm
    thestorm Member
    Jul 13, 2000
    494
    +7
    Hi All
    I would like to reset my PCH A-110 to factory settings as I don't have a display on the screen.
    Can you please advise how this can be done?
    I have tried the reset button on the front and there is no joy.
    Shame there isn't a manual supplied with the unit.
  2. thestorm
    thestorm Member
    Jul 13, 2000
    494
    +7
    It's alright guys, false alarm.. I've worked it out!
    - There is no video signal detected with HDMI connection during initial setup.
    Connect your PCH to the Composite input of your TV
    Boot up and you should see first boot up logo
    Wait until the screen goes blank
    Press TV Mode + 1 for NTSC or TV Mode + 2 for PAL
    If you see the color menu in Composite try to set the HDMI output at Setup -> Audio/Video and do a save.
    Connect your NMT to an HDMI input of your TV.
    Power up PCH
    • Thanks Thanks x 1
