Paradigm Servo 15 to a BK Monolith Plus
Discussion in 'Subwoofers' started by KWB1, Feb 22, 2012.
  1. KWB1
    KWB1 Member
    Aug 10, 2009
    455
    +20
    Just ordered the Monolith Plus FF in Cherry - having had the Paradigm Servo 15, Im hoping it will be as good - if not better! :D
    Ken
    Mods can you edit the title to Paradigm Servo 15 to a BK Monolith Plus Monolith lol
  2. Member 96948
    Member 96948 Active Member
    Nov 18, 2005
    9,918
    +1,856
    It will be interesting to see if you hear much difference. The Monolith has alittle more bottom end output, but the Servo has a little more control...
    Russell
  3. KWB1
    KWB1 Member
    Aug 10, 2009
    455
    +20
    Hey Russell, if it can wobble the sofa like the Servo did, then I will be happy :D
    A quick question for you... is it right that the normal Monolith goes a bit lower than the 500watt plus Version??
    Ken
  4. SBanga
    SBanga Active Member
    Mar 23, 2005
    2,008
    +271
    I went from a Servo 15 to a Monolith (non plus version) and didn't regret it one bit. The normal version supposedly drops a couple of Hertz lower than the plus but this shouldn't be very noticeable.
    • Thanks Thanks x 1
  5. KWB1
    KWB1 Member
    Aug 10, 2009
    455
    +20
    I did have 2 Servo's - much better balance than the one and they really dug deep so I will probably be on the Phone to BK for a second Monolith + if i'm Happy :D
    Ken
  6. Member 96948
    Nov 18, 2005
    9,918
    +1,856
    Yes and no. The LAB 12 driver has a slightly higher resonant frequency, which means the Monolith Plus rolls off slightly sooner (2Hz maybe) but nothing significant. The Plus counters by going slightly louder and as room gain is factored into the equation too, you'd be hard pressed to measure, never mind notice, this slightly earlier roll-off. You would, on the other hand, notice the extra output and so that's the only difference of any real significance.
    Russell
    • Like Like x 1
    • Thanks Thanks x 1
  7. Ianfromnotts
    Ianfromnotts Active Member
    May 16, 2003
    2,504
    +173
    Been playing about with my servo 15s today. REW now shows my mains basically flat to 17hz and -1.5db at 15hz and virtually all of the boom I had with the non equalized mains has gone.
    I was running the subs as a stereo pair next to the mains but it was never 100% successful. Today I finally got round to running them as a mono pair. One at the front of the room and one at the rear much much better.
  8. TopMeTom
    TopMeTom New Member
    Sep 8, 2002
    8,237
    +270
    Thats how i ran dual monoliths, god i miss the other one.
  9. KWB1
    KWB1 Member
    Aug 10, 2009
    455
    +20
    What room EQ are you using Ian?
    Ken
  10. Ianfromnotts
    May 16, 2003
    2,504
    +173
    Using the X30 to crossover at 50hz. The mono outputs feed into both channels on an FBQ2496 and then REW for measuring and adjusting. Each sub channel was adjusted independently and some minor tweaks applied to integrate everything with the mains.
    The latest version of REW is pretty amazing what used to take me hours of tweaking is now virtually automated, very little in the way of post auto tweaking needed these days.
    I should have taken a print out of the waterfall before and after but I forgot it was pretty impressive clean up of decay
  11. KWB1
    KWB1 Member
    Aug 10, 2009
    455
    +20
    Nice,
    I had a pair of Servo's and felt the bass had a much improved balance compared to the single Servo,
    This will probably be my route with a pair of Monolith plus's with an antimode
    Ken
  12. KWB1
    KWB1 Member
    Aug 10, 2009
    455
    +20
    Well... the Monolith + just did not do it for me hence me returning it
    I just could not get any real depth out of it - make no mistake - it has all the power when you crank it up - but I dont want to crank it up all the time just to get any benefit out of it
    For me the Servo is in another level to the BK in terms of depth at lower volumes - suprising to me as people and measurments beg to differ
    An important issue is the fact that its 90% music and 10% films and maybe the sealed servo with its 15 inch woofer that has the superiority
    Gutted in a way as the Monoliths finish was supreme for the money
    Ken
  13. SBanga
    Mar 23, 2005
    2,008
    +271
    Just goes to show everyone's experiences are different and measurements are not the be all and end all.
    What's next on the audition list? :devil:
  14. KWB1
    KWB1 Member
    Aug 10, 2009
    455
    +20
    May have to try out whats in your sig and see what all the fuss is about! :thumbsup:
    Ken
  15. SBanga
    Mar 23, 2005
    2,008
    +271
    That'll be much easier once HiFix start stocking the SVS range. Let us all know your thoughts.
  16. canada16
    canada16 Member
    Nov 15, 2009
    813
    +26
    They are supposed to be getting stock by tomorrow, but still no prices as of yet.
  17. W124coupe
    W124coupe Member
    Dec 27, 2006
    496
    28
    +44
    I feel the same about the XXLS400 in our sunroom. I think the root cause is that newer (more expensive) amp designs use DSP to vary the low Hz boost, maximising the extension at lower levels and backing off as the tap is opened. SVS (certainly on the SBs), KK, MKsound, Velodyne all do this.
    BK's amp uses a fixed LT circuit (soldered components) to extend response and therefore has to be tailored to not exceed Xmax at full tilt, wasting potential extension at day to day levels.
    So, if you are regular hooligan, BK makes you smile. If not, it makes you miss stuff the others can provide in the same or smaller space but for more ££££.
    My mate is running 2 SB12-NSD as stands for his MA Apex set and they are stunningly better than the single XXLS400 at normal levels. Just as clean higher up too.
    I'm very tempted to do the same.
  18. KWB1
    KWB1 Member
    Aug 10, 2009
    455
    +20
    Interesting stuff :thumbsup:
    Looks as though Hi Fix (close to me) will soon become stockists of SVS and the Sealed SB13- Plus will be on my listening list as well as the above mentioned
    Ken
  19. TopMeTom
    TopMeTom New Member
    Sep 8, 2002
    8,237
    +270
    Could be wrong but dont think the sb13+ is available over here anymore?
  20. W124coupe
    W124coupe Member
    Dec 27, 2006
    496
    28
    +44
    It's not.
  21. W124coupe
    W124coupe Member
    Dec 27, 2006
    496
    28
    +44
    Interstingly, we had a look inside the SB12-NSD yesterday and I'm surprised to say the driver is uncannily similar to the Peerless XXLS......
    So, I went back to the Svsound site and looked at the driver pics there. When you load them up, the image names start 'XXLS'!
    I think we have an 835017 being used here.....ie the Alu cone version of the BK XXLS400 and Mono driver. It would certainly explain the very good music results as these drivers are very clean up high.
    Given Tymphany manufacture in HK/China now and the UK SVS SB subs also come from there I guess it makes sense....
  22. KWB1
    KWB1 Member
    Aug 10, 2009
    455
    +20
    Having been recently re-united with a Paradigm Servo 15 - for me (and the other half) both agree that the Servo 'feels' and sounds far better than the BK Monolith Plus in my room.
    The low frequency wobble at lower volumes and a much cleaner bass makes it an utter legend :thumbsup:
    Ken
  23. Member 96948
    Nov 18, 2005
    9,918
    +1,856
    As with all things audio, there are no absolutes. The Monolith is ported, the Servo is sealed, relying on larger driver area. There is no guarantee the two will react the same in a given room, even if the drivers are in the same place.
    On paper, one of my DIY 15" subs should outperform a single Monolith, but in my old room it wasn't the case. However, the converse was not true - A pair of the 15" subs was so far ahead of a pair of Monoliths, it wasn't funny.
    You have the room that you have and the best sub is the one that works in it. EQ mops up the rest.
    Russell
    PS. Even if all the figures are the same, there's something inherently natural about the way a large driver moves air, compared to a ported sub. Even if you need more of them...
    • Thanks Thanks x 1
  24. samhain
    samhain Active Member
    Apr 1, 2004
    2,654
    +117
    I have the SB13 and its a beast. That man Russell likes it too ;) SVS have taken if off for sale to do some minor cabinet updates but I am led to believe that it will be back on soon. If it's better (I suspect it will but not by much) then it will provide many smiles as does mine
  25. KWB1
    KWB1 Member
    Aug 10, 2009
    455
    +20
    Most Reviews suggest the SB13 is a great sub - for me tho the Servo continues to tick all the right boxes - Power / depth / Very low distortion and price
    Having owned the Velodyne DD18, the Servo did not equal it - but it was bloody close - to my ears (and trousers) 2 servo's bettered it - for around £600 for both, it was a no brainer
    Ken
  26. samhain
    Apr 1, 2004
    2,654
    +117
    I didn't have the benefit of exploring the limits of my servo 15 in the room I had but it could shift alot of air that's for sure
