Panasonic Viera and SA-BT100 audio problem
Discussion in 'All-in-one Systems' started by Jezzer96, Jan 11, 2009.
  1. Jezzer96
    Jezzer96 Member
    Nov 13, 2008
    10
    I have a new Panny Viera 46pz81 plasma and the SA-BT100 cinema system.
    The problem I have is that when I want audio from the TV and home cinema system at the same time, there is an echo from the overall sound reception.
    The SA-BT100 is set to AUX/TV. The only way to get a decent sound is to turn the speakers on the TV off and just use the audio from the SA-BT100 speakers.
    Is it possible to have speakers working on the plasma at the same time as the SA-BT100 speakers?
  2. kentish_lad
    kentish_lad Member
    Sep 14, 2006
    1,625
    +217
    You should always mute the TV when using a HT system, theres no purpose in having the TV speakers on aswel which will give out an echo you describe
