Panasonic Receiver Cable Extension
Discussion in 'Cables & Switches' started by Yid219, Aug 5, 2007.
  1. Yid219
    Yid219 Member
    Jul 4, 2004
    36
    11
    Hi all,
    I Have had my Pan TH42PW6 plasma always connected to the Pan TUPT600B receiver and now have to move the plasma without taking all the cables out of the wall. What I am looking for is a cable extension which will connect to the display cable supplied with the receiver. The cable has a 26 pin connection on it and I only need to extend it by about 2 metres max but can't seem to find one anywhere.
    i would really appreciate any help with this as apart from knowing it has 26 pins and conects my receiver to my plasma, I don't really know anything about this type of cnnection cable or if it has any specific name !!!!!
    The only info on the cable in the manual states it's a D-Sub 26 pin.
    Thanks for any help.
  2. Craig K
    Craig K Member
    Feb 26, 2009
    3
    Did you have any luck with this?
    I have now got the subD 26 pin connections and sourced a 50 wire cable.
    Just now wondering whether to proceed - whether it will work or not?
    Many thanks
    Craig
  3. tbb
    tbb Guest
    i see your post is from awhile ago, but did you have any luck? i am having the exact same issue.
  4. Craig K
    Craig K Member
    Feb 26, 2009
    3
    I did, and it worked!!
    I bought the cable from a local retailer and sourced the plugs from a manufacturing company called xxxxx (actually on reflection I better not publicise). I feel bad dropping their name on here since they really only deal with large orders (like 1,000 at a time!). They did it as a once off for me.
    It worked second time round for me because I was having a not so bright moment and forgot that the soldering joints needed to be a mirror image of each other :suicide:
    MH connectors didn't give me the name of someone they supply with this particular plug.
    You can buy a ready made cable from Panasonic, but they charge something like £100 for a 15 meter extension - and I needed 20 meters.
    Good luck!
