42ST30. green on right, pink on the left.
Only had it a week.
Can only see it on the DVB tuning screen though, normal viewing doesn't really show it up thankfully.
TX-P50VT30B
R/H side of screen slight 'Green' tinge
S/N FB16400xxR
Not informed Panasonic as of yet
Noticed slight green sky tinge from day 1, Late December 2011
Just tried Grey slide today and confirm 'slight' green tinge R/H side.
Thought i'd done this? sorry 'Scooby'
PS, I would have liked to have my ''EXTENDED WARRANTY'' ( posted 3/01/12 ) in my hand before handing over this information ( S/N ) ?
50vt30 number 155
Completely clear until about the 1000 hour mark then overnight green splodges,extreme banding and colour issues down the r/hand side and very easy i/r from the epg but none from hours of gaming,the so called update reduced the splodge alot but it's still visible on about 60% of all content,panasonic have been made aware through tps.
If you wish to post a picture of your screen showing the issue feel free to add this to your post if you wish. A link will be provided to some grey slides that show the issue more clearly in photos. If you have the time can you please use the slides and post a single picture showing the issue on your set.
UPDATE.....
If you have a set with this issue please contact your retailer and then Panasonic on this number 0844 844 3899 and ask to speak to Dominic.
Please also add:
Your sets serial number found on the back of the set. leave this blank if you wish or just add the first two numbers.
If you have informed Panasonic of your issue.
How long it was before you noticed the issue on your set.
Could have sworn I posted details when I voted.....anyway:
42 S30 - serial starting with 155 and so apparently updated at factory. Quite noticeable on the right and both top corners. Noticed straight out of the box.
I'll post on behalf of my uncle:
50 S30 - huge blobs (really bad) left and right of the centre. But he can't see them :/ - issue noticeable right out of the box.
edit: contacted Panasonic but informed them I'll run in for 100-200 hours and see how it goes.
50GT30 slight green blob straight out of box faded considerably after a few hundred hours. Contacted panasonic about the fault and I've had the update applied. Will report back in a few days to give feedback with regards to it's effectiveness on my set. Serial number 131 and I have had no other issues.
UPDATE - Set is now back with the retailer and my money has been refunded as the fault worsened after the SD card update was applied. Was "Livable" before this and did seem to improve as the panel settled. I would advise against getting the update if you can tolerate the tinge.
