No problems guys...
So anyone with a
Logitech Harmony 520, 525, 555, 668, or 855 remote with a Panasonic device that is known to be able to be made region free with the
codes from this post, then PM me and I'll send the details of the account for the device with the codes programmed in to the 1 to 9 and 0 buttons.
Below is a list of Panasonic devices that work so far:
DMP-BD30 Blu-Ray Player
DMR-EZ27 DVD recorder
DVD-S53 DVD player
DVD-S54 DVD player
DMR-EH57 HDD/DVD recorder
DMR-EX77 HDD/DVD recorder
DMR-EX87 HDD/DVD recorder
DMR-EZ47V DVD/VHS recorder
The region free hack procedure:
* Login to the region free hack account
* Update your remote
* Select the only device on the remote
* Switch your player on without a disc in
* Point the remote at the player and press 1, 2, 3, 4, 5, 6, 7, 8, 9, 0 in that order
* The player should then reset and be region free, if not, try the process again.
Good Luck! Leave a THANKS if it works for you!
