I, like many others, can vouch for son_t's hack. Worked brilliantly with a DMR EX75, using my Harmony 525.
Thanks for this, I spent ages trying to use my N95 and irremote, several versions of tv remote controller on PPC and a couple of laptops with IR!Hi Everyone. I downloaded the file with the step-by-step screenshots from the german forum and translated it to english and added some text to make it easier to understand. I hope it's ok to repost it here (there was no copyright in the material, so I guess, it's ok, right?
The link to the .pdf file is http://www.hejdo.wz.cz/Panasonic-DMR-EX85-Regionfree.pdf
I also attached it to this post, so it would be easier for people to get hold of it.
Hi there, from browsing the forum did I get right:
- no hacks for the Panasonic SA/SC - PT models (I have an SA-PT950)
- requires chipped remote
Where could I get a working remote, am a little scared about spammers from Uk which seems to offer working chipped remotes.
All help much appreciated!
cstf
problem's solved by a multiregionugrades.com kit
Thanks, Antonio
Any words on this one?
With regards to your comments about people from the UK apparently being spammers with chipped remotes, sorry but what are you on about? Where is this spamming you refer to, theres only comments from people whom have used said remotes? No-one on this forum has done this spamming you refer to that I`ve seen. This thread discusses the FREE hacks that can be done yourselves for some Panasonic models.
There have been many bad comments and even investigations as far as I remember in this thread on http://www.dvdcodes.net/ so that is the reason I am a little hesitant to just order at any place a chipped remote.
So because one site has a bad reputation, you assume that all UK suppliers are spammers or are troublesome? Not to mention the fact no-ones spammed anything on here anyway so why state that in the first place? Read the earlier threads, search the forums, do a google search, theres many, many reputable places that have supplied modifications for many many years, including the forum sponsor below.
At the end of the day, if you want to mod your model you don`t really have much choice you need a clone of the factory remote and theres plenty of posts on earlier pages where you can obtain these that work.
Ah, another thing, why are these remotes only sold from the UK, is that a legal problem?
I want to send you a PM, but I'm not aloud because I have not posted enough posts. I'm looking for a hack to make my DMR-EH57 region free and your cd iso image sounds like the soulution, but I need the link to it. Do i need any detailed information on how to make it work or is it easy with the iso image?I've successfully taken the disc and made a bootable CD ISO image ... anyone wanting it drop me a PM for a link
I tried searching the forums and read through this thread but cannot find if the portable Panasonic LS86 can be hacked for multiregions. I want to purchase this player because of the long battery life but want to know if I will be able to crack it or not. Any one knows?
It's not mentioned if anyone has tried this on a harmony 885, nor on a Panasonic EX47V, however if i can get the files then i'm prepared to give it a shot
Paul
Has anyone successfully got the Panasonic DMP-BD30 Blu-Ray Player region free. I followed the instructions on the dcevolutions website and using a laptop/boot disk but no joy
I know this is an old model and previously there has been no definitive hack, but wondered if anyone had come up with a hack for a Panasonic L50. It is a PAL Region 1 - I need region 4 or free. Have tried Virus's CCF file on my pocket PC - didn't work
