I don't understand why one file has been downloaded more than the other when both files are needed to extract the ISO....lol
Hello from germany,
my english is not so good.
I have a Panasonic S53, and would like to switch him codefree.
I have 2 all 4 one remote controllers, look at the picture:
http://img1.bildupload.com/fd07f7892f49180e31284ded28fda86e.jpg
Can somebody help me in German?
Oder kann ich mit dir auf deutsch schreiben?
1. Burn the CD from the ISO.
2. Make sure laptop boots from the CD before the HDD
3. Set COM2 to IR in BIOS if not already done.
4. Boot the laptop with the CD
5. Change directory to WINAMP
6. Run WINSAMP
7. Load the text file
8. Have DVD recorder on and no DVD in drive and DVD selected.
9. Point laptop at DVD recorder press enter
10. More cursor to right and wait 5 secs, pless enter again....
11. Continue until all codes transmitted.
12. See Hello on recorder
13. Switch the recorder off via remote
14. Unplug power lead for 10 secs
15. Reconnect power lead and wait until ready
16. Turn on and be happy as multi regional.
No problems guys...
So anyone with a Logitech Harmony 520, 525, 555 or 668 remote with a Panasonic device that is known to be able to be made region free with the codes from this post, then PM me and I'll send the details of the account for the device with the codes programmed in to the 1 to 9 and 0 buttons.
Below is a list of Panasonic devices that work so far:
DMP-BD30 Blu-Ray Player
DMR-EZ27 DVD recorder
DVD-S53 DVD player
DMR-EH57 HDD/DVD recorder
DMR-EX77 HDD/DVD recorder
DMR EX87 HDD/DVD recorder
The region free hack procedure:
* Login to the region free hack account
* Update your remote
* Select the only device on the remote
* Switch your player on without a disc in
* Point the remote at the player and press 1, 2, 3, 4, 5, 6, 7, 8, 9, 0 in that order
* The player should then reset and be region free, if not, try the process again.
Good Luck! Leave a THANKS if it works for you!
Hello Forum,
I have a panasonic DMR-EX87. Yesterday I tried the PC IRDA hack. I created a bootable cd. Copyed winsapm.exe and the remote.txt on it and booted my Toshiba Tecra T9000 with this cd. I started winsamp (sometimes with the C2 =COM port 2 option and somtimes with C1). I followed the instructions but nothing happened. Nor did anything change in the DVD s display during programming neither did it accept US region dvds afterwards (I bought my EX87 in Germnay, it is PAL). I tested the irda interface under WINDOWS (connecting the pc via irda to my mobile phone) and it worked. The bios of the Tecra T9000 has not settings for irda. Maybe irda doesn't work with DOS (bootable cd has a dr dos image). I s there a programm like winsamp that works under WINDOWS (XP)?
Best regards, Antonio
Is anyone else getting referred to a similar device (dvd-s26) when trying to find the dvd-rfh in the Harmony software?
You need to get in touch with son_t to have the correct user profile in order to download device dvd-rfh
Good luck
